Show me pictures of those SUPER DUTY'S working.
#2883
Thanks! Took a few years to find a decent setup that was able to be easily removed if I needed the dump trailer for other jobs.
I fabricated the mount for the leaf loader myself. Not bad for a complete novice welder.
Yes sir, Turf Tracer indeed. Don't mow a ton so it's got quite a few years on it. Good eyes.
#2884
#2885
Received 5,149 Likes
on
#2886
#2887
#2888
Yea, mowers are ridiculously priced. $12k for a nice Z and lawns that go for nothing. But that's a conversation for another site.
#2889
Today, I am taking 6 logs to a local saw mill to have made into 2x4s, 2x3s, and some 1 bys. The logs are straight, clear, and what I believe to be Western Red Cedar that supported a 69kV transmission line running across my property. When they came through to replace them with steel poles, I asked if I could have some. They left me the ones from my property and surround properties!
According to a log weight calculator, there is about 2,000 lbs-worth here.
#2891
#2892
Haha, true! My 250 has the overload spring like a 350, and sitting here in the parking lot, the rear of that spring is certainly engaged, but the front is about half an inch from engaging, and there is still a bit of travel yet until the bump stops. It makes me wonder if I should upgrade to F-350 blocks in my rear suspension so that it would sit more level in these circumstances.
#2894
Maybe that would be the thing to do. My truck sits higher in the front end than most, so I wonder if I would end up with an odd rake angle. I think it has the heavier front springs on it. When unloaded, I'd say the truck is perfectly level. I guess I'd have to get new ball mounts, though.
#2895
