Windsheild Wiper knob -- stripped (1990 F250) - Ford Truck Enthusiasts Forums
Old 11-19-2010, 12:36 PM
JoeVR5's Avatar
JoeVR5 JoeVR5 is offline
JoeVR5 is starting off with a positive reputation.
Windsheild Wiper **** -- stripped (1990 F250)
Hi guys,
I lent my 1990 F250 diesel 7.3L to a buddy, and when I got the truck back the wiper **** was stripped out and came off in my hand.
Is this a **** that I can replace? . . . or should I buy an entire new switch? I can't find it at Autozone . . .
Thanks everybody!
Old 11-19-2010, 12:39 PM
karjunkie's Avatar
karjunkie karjunkie is offline
karjunkie is starting off with a positive reputation.
ya, you should b able replace just the ****
Old 11-19-2010, 04:39 PM
96ford250 96ford250 is offline
96ford250 is starting off with a positive reputation.
I replaced the whole arm when i did mine you just take off the crowl and there right there got mine from the JY painted them up greased them and installed works like a charm
Old 11-19-2010, 05:13 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
Still available from your Ford dealer, MSRP $13.82. Or, you could probably find a universal **** with a set screw that would be better than the cheesy plastic **** they came with from the factory.
Old 11-19-2010, 05:32 PM
i got both arms for $20 bucks at the JY they had aluminum ***** i guess its all up to what you want to do i painted under my crowl too to fix some surface rust so i just replaced them anyway
Old 11-19-2010, 05:37 PM
They have whole new arms for brand new ones you cant beat it i remember the local places had them for $120 a side
1980-96 Ford Truck/bronco - Exterior Parts - Wiper Parts
Old 11-19-2010, 06:43 PM
JoeVR5's Avatar
Thanks everybody!
I was at O'Reillys today and I found an old Ford "Radio ****" that fit the half-moon shape of the wiper switch stem. It was a bit tight, but at least it's not coming off any time soon.
Best part was that it was only $5. I'll keep my eye out in the scrapyards for a true replacement though . . .
Old 11-19-2010, 06:46 PM
wow im retarded i thought we were talking about the ***** your wiper arms connected to
Old 11-19-2010, 06:57 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Old 11-19-2010, 07:11 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Do what seams every other noob does when that happens, put a wad of paper towel on the end of the shaft, then jamb the **** back on it again!
Old 11-19-2010, 07:25 PM
wycowboy63 wycowboy63 is offline
wycowboy63 is starting off with a positive reputation.
There is a universal **** in the HELP! section at your local parts store. It has set screw. I have one for the windsheild wipers on my F150, works great. I paid less than $5 for it.
Chris
1990 F250 windshield wipers wont turn off 1990F250Beater 1987 - 1996 F150 & Larger F-Series Trucks 3 12-16-2016 05:42 PM
Wiper knob frustration DonkeyF350 1973 - 1979 F-100 & Larger F-Series Trucks 7 06-26-2016 06:10 PM
WTB: 1975 F250 Wiper Switch with knob 1975FordF250 WTB - Parts & other 2 07-04-2015 11:23 AM
F150, 1990 bob.p 1987 - 1996 F150 & Larger F-Series Trucks 2 06-02-2014 11:21 PM
remove dash switch knobs 334eagle 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 05-21-2010 09:35 AM
Tags
1987, 1990, 250, 90, broke, f150, f250, ford, knob, stripped, switch, truck, windsheild, windshield, wiper, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
