Go Back   Ford Truck Enthusiasts Forums > Marketplace > Want to Buy > WTB - Parts & other
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
  #1 (permalink)
Old 11-19-2010, 10:44 AM
JustBlaze's Avatar
JustBlaze JustBlaze is offline
Garage is empty, add now
JustBlaze is starting off with a positive reputation.
cab frame brackets + 351m/400 motor towers & parts
I am looking for a good set of these if anyone has them:
Click the image to open in full size.
I also need a set of the frame towers for a 351m/400 that would bolt in to a 77' f150.
My truck has 6 cylinder mounts now and I'm building a 400 for it.
I could also use parts for the 400 such as distributor for duraspark, intake, valve covers, oil pan, etc... all the small things.
Thanks
-Justin
  #2 (permalink)
Old 11-19-2010, 12:08 PM
c.l.nye's Avatar
c.l.nye c.l.nye is offline
c.l.nye is starting off with a positive reputation.
I have a set from a 78 f150 4x4. I can check on them weekend and get picsfor you.
__________________
Chris
1977 F150 4x4,360,NP435,NP205 44 in front 9" in rear,4in lift and 32s
  #3 (permalink)
Old 11-19-2010, 12:27 PM
JustBlaze's Avatar
Quote:
Thanks, I appreciate it.
  #4 (permalink)
Old 11-19-2010, 01:15 PM
Screamin T/A Screamin T/A is offline
Screamin T/A is starting off with a positive reputation.
I have everything that you need except the good cab mounts. I have everything motor related though. where are you located in NY? I may be able to assist in delivery also....let me know
  #5 (permalink)
Old 11-19-2010, 01:22 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
What is this 1977 F150, a 2WD or 4WD? The engine supports do not interchange.
D7TZ6028B (replaced D0TZ6028A) Right & D7TZ6029B (replaced D0TZ6029A) Left .. Engine Supports aka towers, stands, perches.
Fits: 1969/79 F100 302 / 1975/79 F150 302 / 1977/79 F100/350 351M/400 2WD
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #6 (permalink)
Old 11-19-2010, 01:36 PM
JustBlaze's Avatar
It would be for a 4x4. I knew they were different but forgot to mention which ones. I actually have a question for you. Would any towers 351/400 towers bolt up to my 77 frame or were there multiple styles for the 4x4's over the years?
  #7 (permalink)
JustBlaze's Avatar
Quote:
I'm located in Cobleskill. Where are you located?
  #8 (permalink)
Old 11-19-2010, 01:41 PM
Cobleskill!!!! My family has a house in Sprakers...we're almost neighbors...oh yeah the towers that i have are from a 79 F150 4x4..they should be fine. I know the 250 4x4 are NOT the same...if you are not in a hurry for these parts, i am planning on heading up there around new years time....maybe earlier..let me know what else you need, or how you want to go forward...you can PM me also...
  #9 (permalink)
Old 11-19-2010, 01:53 PM
Ford Parts Guru
2013 Ford Escape
Quote:
What are the last six digits of your trucks VIN? Is it a Super Cab or not?
Despite what someone claims (he has no Ford truck parts catalog-I do), some 1977/79 F150 351M/400 4WD's use the same supports as F250 4WD's and 1979 F350 4WD's, some do not.
Since there are three different types, I'd rather not have to type six (3 right/3 left) different part numbers, so I need the info.
__________________
  #10 (permalink)
Old 11-19-2010, 02:03 PM
Well, I stand corrected. I have never seen a 79 f150 with the same towers as the same year 250/350. I also have never torn down a supercab....I apologize. That being said, i still may have what you need... I could also give you the vin from the truck my part are coming off of...
  #11 (permalink)
Old 11-19-2010, 02:08 PM
JustBlaze's Avatar
I'll post up the vin when I get back home in a hour or so.
That's awesome that you guys have a house in sprakers screamin t/a.
One of the guys from my dads work actually lives in sprakers and has a black gta with a 383.
Do you still have the whole truck that these towers are from? Might have a lot more useful parts than I realized.
  #12 (permalink)
Old 11-19-2010, 02:13 PM
I have almost all the truck, in addition to a whole mess of parts for 73-79 trucks. I even have the frame and entire rolling chassis from the 150..engines, axles, wheels, trans, etc..lots of little stuff too..just sold a mint shortbed off of it..
  #13 (permalink)
Old 11-19-2010, 07:03 PM
fordman75 fordman75 is offline
1996 Ford E250
My Garage
fordman75 has a good reputation on FTE.fordman75 has a good reputation on FTE.
JustBlaze I've got a pair of 351M/400 motor mount frame perches/towers off a 78 F250 4x4. If you can get me the measurement from the center of the top perch/tower mounting bolts to the inside edge of your frame I can tell you if mine will fit yours.
__________________
Ted
1954 F100 4x4, 300, NP435/NP205
  #14 (permalink)
Old 11-20-2010, 06:36 AM
Ford Parts Guru
2013 Ford Escape
The OP sent me the VIN in a P/M:
1977 F150 4WD Regular Cab serial number Y4XXXX.
D8TZ6028C .. Right Engine Support-351M/400.
D8TZ6029D .. Left Engine Support-351M/400.
Fits: 1977 F150 4WD before Y20,001 / 1977 F250 4WD before Y20,001 (High Boy).
Fits: 1977 F150 4WD from Y20,001 / 1978/79 F150 4WD Regular Cab.
__________________
  #15 (permalink)
Old 11-20-2010, 01:01 PM
So, The towers I have will work perfect for you.
Tags
302351m400, 351, 351m, brackets, buy, catalog, f100, f150, ford, frame, motor, mounts, parts, perches, towers, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
