Extended-cab shortbed 4x4?
Alright so I have a 77 f250 single cab long bed. The bed on her is shot and the cabs starting to go however the frame is real strong and the 460 in it is a jasper crate with under 10k. How hard would it be to put an extended cab on here with a short-bed? I dont think ford every made a truck like that, but ive seen one or two float around on here. Thanks for any help at all!
I used a 73 highboy frame with a 77 2wd supercab. There are some mods that have to be done for it to line up properly. Front cab mounts line up but need 1 1/2" body lift for the fenders to line up. The rear mounts are in a different place. I removed them & used 3" body lift mounts & relocated the holes in the cab to mount directly to frame. Also have to cut a hole for the 4wd shifter. I got a tranny cover hump from a donor 4wd & traced & cut the hole in the super cab. I'm not done with it yet, so I'll let you know if anything else pops up. Feel free to ask any question
Broncster72
22
10-08-2020 04:38 PM
ethomps
08-27-2015 09:35 PM
