1996 F-250 7.3, 4X4, Front U-joints
The passenger side has two u joints. One is near the wheel and one is right at the diff. The one at the wheel can be taken out by unclamping the boot on the sxle stub. You then pull the axle stub out and you have two short shafts connected by a u joint. This is all done AFTER you remove the wheel, brakes, hub/rotor, and spindle. The joint near the diff can be removed if you can somehow get the joint out with the stub in place which is unlikely. To get that part of the stub out you have to take out the whole axle assembly and split open the pumpkin. There's a "C" clip that holds the axle inside the case. Remove that and you can pull the axle stub.
94E1504.9L
06-24-2009 11:53 AM
gene17847
07-29-2008 10:28 PM
