Hitting the gas pedal while braking on the 2011 F250 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
View Poll Results: Has anyone hit the gas pedal while braking on a Ford f250-SD?
Yes 18 30.00%
No 42 70.00%
Voters: 60. You may not vote on this poll
Old 11-18-2010, 03:30 AM
cdrswenson cdrswenson is offline
cdrswenson is starting off with a positive reputation.
I recently purchased an F-250 SD. This is the first time owning a heavy duty truck. After driving for a short while I experience for the first time what it feels like to hit the gas pedal while braking. I caused a small accident before I realized what I did. I was wearing safety shoes at the time, which are bigger and heavier than regular shoes. I feel there is a design flaw with the pedals being too close together and the brake pedal going too far to the floor where it's almost even with the brake pedal. Obviously, I am much more careful when applying the brakes now.......but has anyone else experienced this?
Old 11-18-2010, 04:16 AM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
i have that issue with my '96 explorer when wearing my steel toe boots for work. but i've never had an issue with my '02 excursion or '98 expedition. i'm not sure of the actual differance(distance between pedals) between the smaller truck and the fullsize ones but its noticeable.
so i'd have to say no i have not had this issue in a super duty/super duty based truck.
Old 11-18-2010, 07:44 AM
PsycoJuana's Avatar
PsycoJuana PsycoJuana is offline
PsycoJuana is gaining momentum as a positive member of FTE.PsycoJuana is gaining momentum as a positive member of FTE.
well kinda did the other day n my 2011 F250. had work boots on and brought up my left foot to rest on brake pedal with my right.
The pedal contuied to depress till i found my right foot was pushing the gas pedal also!
So normally i apply little brake and hardly ever get it to the floor, except the other day! lol and yes now i make sure i move my foot even with my heavy work boots!
Old 11-18-2010, 10:25 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Double Post..
Old 11-18-2010, 10:27 AM
dkf's Avatar
dkf dkf is offline
When the brake is pushed in it is at a similar height as the gas pedal is. The SDs have been like this since they first rolled off the line in 98'. You will have to get used to moving your foot over more towards the centerline of the brake pedal and not the right hand edge of the brake pedal. I wear steel tipped leather work boots a lot also.
Old 11-18-2010, 12:29 PM
Zedrive's Avatar
Zedrive Zedrive is offline
Zedrive is gaining momentum as a positive member of FTE.
Sounds like your feet are too big.
And you know what they say about guys with big hands and big feet.
They wear big socks and gloves
Old 11-18-2010, 01:02 PM
BareBones BareBones is offline
BareBones is gaining momentum as a positive member of FTE.
I also find wearing Sorel snow boots sometimes results in the boots getting hung up on something under the dash. Its a real WTF moment the first time it happens......
Old 11-18-2010, 01:05 PM
driximus's Avatar
driximus driximus is offline
driximus is gaining momentum as a positive member of FTE.driximus is gaining momentum as a positive member of FTE.
its an 02 but I have never hit mine at the same time, Unless I was staging at the track. Are the new ones close together?
Old 11-18-2010, 01:21 PM
J_E_Summit's Avatar
J_E_Summit J_E_Summit is offline
J_E_Summit has a very good reputation on FTE.J_E_Summit has a very good reputation on FTE.J_E_Summit has a very good reputation on FTE.
I haven't had problems with work boots or sorrels and the brake pedal.
I do find that my sorrels hit the transmission tunnel and it takes me a second or two to figure out why I am pushing the gas pedal so hard and not getting any response
Old 11-18-2010, 02:13 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
Never had a problem with any boots or shoes. Just learn some new driving habits.
Old 11-18-2010, 02:40 PM
PERFORMANCE RED PERFORMANCE RED is offline
PERFORMANCE RED is starting off with a positive reputation.
I brake with my left foot so I have never had any issues.
Old 11-18-2010, 02:43 PM
Sebs Sebs is offline
Sebs is starting off with a positive reputation.
I answered yes on the poll even though I have a 2008. And I've done it more then once. I'm getting pretty fast at recovering from it though!
Old 11-18-2010, 05:31 PM
msalyer msalyer is offline
msalyer is gaining momentum as a positive member of FTE.msalyer is gaining momentum as a positive member of FTE.
I have an '01 and it happens occasionally.
Old 11-18-2010, 06:11 PM
Super Steve Super Steve is offline
Super Steve is starting off with a positive reputation.
Quote:
Exactly.
Or take the snowshoes off before driving.
Your incompetence is not Ford's fault.
If you are trolling for supporters for a possible lawsuit, you aren't going to find many here.
Old 11-18-2010, 07:48 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Maybe you should drive a hybrid?
1975 Rear Brake Issue 1975FordF250 1973 - 1979 F-100 & Larger F-Series Trucks 8 07-25-2016 09:44 PM
Brake pressure building Gembone 1967 - 1972 F-100 & Larger F-Series Trucks 15 10-31-2015 08:18 PM
Brake Troubles rcnease Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 09-20-2015 03:46 PM
F-700 no brakes eriksf250 Large Truck 4 10-15-2014 05:30 AM
91 F250 Brake Pedal Play (soft) Rmcmorris 1987 - 1996 F150 & Larger F-Series Trucks 4 08-26-2004 12:51 AM
Tags
2011, 4by4, accelerator, accidents, brake, cap, distance, f250, ford, gas, oklahoma, pedal, pedals, red, stuck, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
