Hitting the gas pedal while braking on the 2011 F250 - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
View Poll Results: Has anyone hit the gas pedal while braking on a Ford f250-SD?
Yes 18 30.00%
No 42 70.00%
Voters: 60. You may not vote on this poll
Old 11-18-2010, 08:36 PM
Ak68F250 Ak68F250 is offline
Ak68F250 has a great reputation on FTE.Ak68F250 has a great reputation on FTE.Ak68F250 has a great reputation on FTE.Ak68F250 has a great reputation on FTE.
Dad does it alot with his 06 F250.
Does not matter what he wears he still hits both pedals.
Bunny boots make it even worse.
Old 11-18-2010, 10:42 PM
KSCRUDE KSCRUDE is offline
KSCRUDE is starting off with a positive reputation.
I think by driving barefoot you will cure your problem.
Old 11-18-2010, 10:46 PM
Quote:
Originally Posted by PERFORMANCE RED View Post
I brake with my left foot so I have never had any issues.
Do you have sex with animals too. Braking with your left foot is so taboo. Not good at all!
Old 11-18-2010, 10:48 PM
bayou barataria bayou barataria is offline
bayou barataria is gaining momentum as a positive member of FTE.
I wear extra wide work shoes and never once had a problem with than on my '08 or my '05 or my old ladys' expo either. Try setting the pedals lower.
Old 11-18-2010, 11:16 PM
loganworks loganworks is offline
loganworks is starting off with a positive reputation.
Just purchased a 2011 250 4X4 Super cab, this is my first Ford and so far I love the truck. I have noticed that you need to re-train your foot to keep from hitting the gas and brake at the same time. It's not a problem once you are aware and take care.
Old 11-19-2010, 03:18 AM
jimhoff jimhoff is offline
jimhoff is starting off with a positive reputation.
My 08 Super Duty was worse about this than the 2011 is. Maybe I've just retrained myself better but I have had zero unintended accelerations. Watch yourself--if I'm not to old to re-learn habits nobody is.
Old 11-19-2010, 03:35 AM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
I went from a 2002 Silverado to a 2008 F250... In my opinion, one should be able to put their entire foot between the two pedals.
it happens every once in a while, but since the engine is generally disengaged from the transmission while using the brake pedal, it's not big deal... the engine just hits 3k or so.
Old 11-19-2010, 03:39 AM
Pocono Super Duty Pocono Super Duty is offline
Pocono Super Duty is starting off with a positive reputation.
Quote:
Originally Posted by Sebs View Post
I answered yes on the poll even though I have a 2008. And I've done it more then once. I'm getting pretty fast at recovering from it though!
Ditto for me too.
Old 11-19-2010, 05:34 PM
slpin slpin is offline
slpin is starting off with a positive reputation.
only on purpose while downshifting to rev match!
looking at the pictures of the pedals (for auto), they do seem pretty close - but arent they adjustable iirc?
Old 11-19-2010, 07:14 PM
driximus's Avatar
driximus driximus is offline
driximus is gaining momentum as a positive member of FTE.driximus is gaining momentum as a positive member of FTE.
Quote:
HAHAHAH
Old 11-19-2010, 07:40 PM
TexasRebel's Avatar
adjustable in and out, not side to side.
While rev matching, I prefer to have to use the heel-toe method instead of using the inside-outside method.
Old 08-22-2012, 04:52 PM
JimmyS JimmyS is offline
JimmyS is starting off with a positive reputation.
Had it happen on my 2005 F350 and on my work 2011 F350 with work boots - just caught the corner with the side of my boot. Pedals are too close together, but our safety officer said it wasn't a truck problem (despite three other complaints), gave me a long lecture about driving with care and explained that it was likely because I did not have the adjustable pedals adjusted correctly. I have four other vehicles, and have driven for 40 years, and this is the first time this has happened, but I am remedying it by trimming 1/2" off the lower left hand corner of the gas pedal - it's plastic, and not a structural piece. Dremel to the rescue! Ford, spread those pedals out!
  #28
Old 08-22-2012, 05:22 PM
bucci's Avatar
bucci bucci is offline
bucci is gaining momentum as a positive member of FTE.bucci is gaining momentum as a positive member of FTE.
I didn't experience this problem yet.
  #29
Old 08-22-2012, 06:07 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
I was hoping this was going to be a burnout thread, my bad....
And no I can't say I've ever experienced this issue.
  #30
Old 08-22-2012, 06:42 PM
Hotpocket's Avatar
Hotpocket Hotpocket is offline
Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.
happened to me a few times on my ole 92 cougar but never my super duty
1975 Rear Brake Issue 1975FordF250 1973 - 1979 F-100 & Larger F-Series Trucks 8 07-25-2016 09:44 PM
Brake pressure building Gembone 1967 - 1972 F-100 & Larger F-Series Trucks 15 10-31-2015 08:18 PM
Brake Troubles rcnease Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 09-20-2015 03:46 PM
F-700 no brakes eriksf250 Large Truck 4 10-15-2014 05:30 AM
Spongy or soft brakes? 92 F250 4x4 jmgrif 1987 - 1996 F150 & Larger F-Series Trucks 4 08-07-2012 08:21 AM
Tags
2011, 4by4, accelerator, accidents, brake, cap, distance, f250, ford, gas, oklahoma, pedal, pedals, red, stuck, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
