Slide in Campers
My dad just received his 2011 F350 dually that he bought to get his weight on the proper side of the rating, he has a snowbird camper with one slide and he has weighed in at over 13000#'s with his old short box single wheel, which was almost 2000#'s over weight, now he will be a lot closer with the new truck. He had air bags on his truck but only because he was getting flashed for high beams from other drivers. These trucks are more stable with the heavy loads from the slide in campers if they are able to rest on the overload springs. When you crank the airbags right up to bring the truck to empty ride height you can make your truck very unstable.
RV's are currently exempt from mandatory entrance into the weigh stations.
I f you think you are overweight I would not voluntarily go into a weigh station looking for answers. You may only get questions like "how are you gonna get your now captured overweight truck home"?
When I was coming back from Nashville to New Jersey last year we heard a few reports of campers being spot checked at the Ohio borders. If you were overweight you were turned around and refused entry.
Received 5,158 Likes
on
One other camper to consider is the Adventurer 950B - probably the most closely featured compairson to the Lance 992. Very similar campers - main difference is the 950B has a double bunk option to allow sleeping for 6 and the rear step bumper design may be the best in the business. It only has a single slide option but it is also a very viable option for these trucks.
To be honest, I can't decide between the two at the moment - almost splitting hairs for our family of 5.
Weights are about the same for both.
Here is Advernturer website info:
Adventurer Truck Camper Exterior Features - Manufacturing Truck Campers Since 1969
SuperSprings Self-Adjusting Suspension Stabilizers
They don't have 2011'a listed yet but hopefully soon.
Ditto on Fat_Tire - grossly overloaded.
Do NOT go to a state or DOT run truck stop. They are the law and if overloaded they are in a tough spot if they let you go and there is an accident on your way home. Use the fuel truck stops - only $10 bucks, unload and only $1 or $2 more for a re-weigh; get hooked and unhooked weights for less than $15. They will also weigh tandum axle trailers an axle as a time as a re-weigh.
How bad is bad? 450 when at max (not over on either axle but at max GVWR) is 1/2 inch from rear axle bumpers (bottoms out with a thud pretty easily) and the back of truck bed is 4.5 inches lower than when empty. This loading actually lifts about 600 pounds off the front axle and moves it to the rear. Air bags don't add to the weight rating (frame and brakes, sometimes but not in this case tires constain that) of the truck. Bags, adapters, compressor and tank do add about 100 pounds of weight but level up the appearance.
Forget what Ford says it can do, go to the scales and you realize that a 8600 "shipping weight" empty truck is right at 9800 with just the 2 persons normally traveling, full fuel, hitch and normal tools/stuff under/behind the seats.
That said, ABSOLUTELY it can pull it.
My Lance 820 without slide shows a dry weight of 2100lbs on the sticker. Loaded ready to go it weights 4K honestly. I weighed it on Cat scales a few times by front axle only/rear axle only,full truck with camper/no camper.
What Lance doesn't tell you is AC is extra as well as other options and add ons as well as water,etc.
Go to RV.net and those guys will help guide you with honest figures for what your doing.
My SRW F350 handles it fine. Always did. Doesn't exceed rear or front axle ratings or tire rateings.
on
on
#28
There are alot of reasons why I don't want a fiver...I think they are really nice but its just more than I want to deal with size wise...by itself and when pulling my boat behind it..plus I haven't found a fiver yet that can handle pulling a boat of my size behind it.
#29
These are alot of answers to my questions guys!! I really like the extended overload snubbers...I most definately will get those.. Sounds to me that without a doubt I'll be legally overloaded but the truck can handle it but I probably won't be messed with....if I do get messed with I'll have to move weight around to the boat or go rent a truck quickly to get the weight out of it and leave the fuzz and reload..lol
#30
