Long tube headers obx or pacesetter?? - Ford Truck Enthusiasts Forums
Old 11-17-2010, 08:20 PM
mjbll mjbll is offline
mjbll is starting off with a positive reputation.
Has anyone here installed long tube headers on their truck?I have a 02 Screw 2WD with 5.4 motor.After researching I definitely want the long tubes over the shorties.So far I have an Edge programmer,BBK underdrive pulleys and Flex lite Efans. If anyone is running them,which brand out of Pacesetter and OBX are better?Anything else is out of my price range.Also has anyone noticed a difference in the performance of their truck after installation ?
Old 11-17-2010, 09:54 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
I have OBX and i love them, they look good, fit great, and opened up the truck alot.. Im down to a 16.1 with my sig truck, and i need to re custom tune it... I know i can get to the 15's now.
Old 11-17-2010, 10:30 PM
Where in the powerband did you feel the greatest gains?Will I need to send my Edge to Gryphon to get a custom tune?I`m running the Gotts intake mod now but I have an "ebay" type WAI I may install after headers but I dont want to run too lean.
Old 11-18-2010, 08:42 AM
My gains where everywhere, but im not the best to ask. I had 4.6l manifolds on my 5.4l since i put it in.... So the flow capacity was much improved over the manifolds i was using. I knew the 4.6l manifolds where holding me up considerably.
Im not sure on if you have to have a custom tune, i know i do because of my motor swap.
Old 11-18-2010, 10:06 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Pacesetters are poor quality, I vote the OBX.
Old 11-18-2010, 07:12 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Plenty of people have had no problems with the pacesetters, I have a set but they aren't on yet. Since you have a 2wd you are going to have a much easier go of the whole install. Be prepared for some broken exhaust studs when you take the stock manifolds off.
Old 11-22-2010, 10:20 PM
I ordered the OBXs from a vendor on Ebay.I have began to remove my stock exhaust.Does the transmission crossmember have to be removed?It appears it does but I just wanted to make sure.
Old 11-23-2010, 08:48 AM
I cant remember for sure, but i think its easier with it out. Its only 4 bolts on the frame and 2 two the transmission i believe.
Old 11-23-2010, 10:42 AM
If you cut the cats assembly apart, then yes, you can remove it without taking out the crossmember, but it is easier to just remove the crossmember.
Old 11-23-2010, 05:58 PM
Big Bad Big Bad is offline
Big Bad has a good reputation on FTE.Big Bad has a good reputation on FTE.
I'm just waiting for somebody to build a long tube header for 97-03 4.6 trucks.
Old 11-28-2010, 02:27 AM
highteckredneck's Avatar
highteckredneck highteckredneck is offline
highteckredneck is gaining momentum as a positive member of FTE.
Quote:
pacesetter has some.
i have the shorties just cause they were in my budget but christmas is just around the corner
88 f250 351 4x4 headers s346k 1987 - 1996 F150 & Larger F-Series Trucks 13 12-31-2016 09:29 AM
cracked manifold great! ndfastang 2004 - 2008 F150 1 07-09-2015 05:44 PM
Pacesetter vs OBX longtube headers Plowboy34 1987 - 1996 F150 & Larger F-Series Trucks 2 09-30-2014 10:52 AM
2004 F150 OBX Long Tube Header Help FSeriesGuy04 2004 - 2008 F150 4 05-09-2013 10:35 AM
Long tube header follow ups tiqueman97 2004 - 2008 F150 4 02-27-2013 07:09 PM
Tags
08, 2003, 2010, 46, 54, f150, ford, header, headers, install, lightning, long, longtube, obx, pacesetter, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
