Pennsylvania Chapter Join Chapter, Leader: liftnw8z
I need help with the Edge.
Old 11-11-2010, 08:39 PM
soondg's Avatar
soondg
soondg is offline
My wife's Edge has developed an intermittent starting problem. It starts fine for a few days and then suddenly refuses to start. After letting it sit awhile it will usually start. Also, it doesn't hold on a hill, it will roll backwards. The shifting is also erratic. I took it to the dealer and they said they couldn't find anything. I've checked for TSB's and searched the crossover forum but haven't found anything. Perhaps one of the mechanical geniuses in the Pennsylvania Chapter or the Mid-Atlantic region could shed some light on my lack of knowledge.
Old 11-11-2010, 08:56 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
sounds like a bad ground. start with cleaning the battery terminals.
Old 11-11-2010, 09:28 PM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
Geeesh Joe, sounds like you have a good one going here.
Old 11-12-2010, 07:54 PM
soondg's Avatar
soondg
soondg is offline
I did do that Charlie, I was actually thinking it may have something to do with the security system. I also posted in the crossover forum so I'll check there to see if anyone has experienced the same thing. As for the trans not holding a hill and the shifting I really don't have any idea on that one.
Old 11-12-2010, 08:02 PM
dustybumpers
could be. I had trouble with a customer's Saturn one time, wound up, it needed new remotes for the doors/alarm. as far as the shifting, the plug on the mlps unit may need to be cleaned, and have dielectric grease put in it. it's on the side of the trans where the shift cable hooks up. drifting in park, I can't help with that one.
Old 11-12-2010, 08:29 PM
soondg's Avatar
soondg
soondg is offline
Thanks for the information Charlie.
It's not drifting in park, when I'm driving and come to a hill, it'll drift backwards instead of holding like most automatics do.
Getting called to my late dinner, I'll jump back on later to check for your response.
Old 11-13-2010, 04:59 AM
dustybumpers
that's not good, that's a pressure problem in the front pump. I have a 90 pick up doing the same thing. it could last the life of the car, could leave you tomorrow. you will eventually loose reverse, I would just live with it for now, my pick up is working on 5 years needing the pump fixed
Old 11-13-2010, 09:06 PM
soondg's Avatar
soondg
soondg is offline
Thanks for that info Charlie, I have an extended warranty so I'll take it to the nearest Ford dealer and ask them to look at it.
Old 11-14-2010, 01:41 PM
dustybumpers
cool. now you have some ammo. let us know how you make out.
c mobley
09-09-2016 04:25 PM
katesdad
6.7L Power Stroke Diesel
34
03-13-2012 09:14 PM
Supercrewzin01
2004 - 2008 F150
15
07-10-2011 03:48 PM
Phrosut
Computer Chips & Tuners
02-09-2009 05:50 PM
gravvy
04-13-2004 09:42 PM
Quick Reply: I need help with the Edge.
