Fuse Box - Ford Truck Enthusiasts Forums
Fuse Box
Old 11-17-2010, 07:58 AM
Alvinmac's Avatar
Alvinmac Alvinmac is offline
Alvinmac is starting off with a positive reputation.
Fuse Box
Still working on swapping the 302 out of my '77 F100 with a 460. I have the engine and trans ready to drop in, but I'm having a hard time finding the frame towers for a 460 that will bolt on the frame. But the question I have now is does anyone have or know where I can find a diagram for the fuse box of the '77 F100. I'm trying to replace a few fuses, but I dont what all the fuses are running. I've searched the internet and have'nt had any luck.
Old 11-17-2010, 10:22 AM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
Here you go. Straight off the Autozone website. LOL
Old 11-17-2010, 03:31 PM
steponit steponit is offline
steponit is gaining momentum as a positive member of FTE.
Old 11-17-2010, 07:37 PM
Alvinmac's Avatar
Fuse Box
Thanks, that's exactly what I was looking for.
Old 01-30-2011, 12:00 AM
Daveyj Daveyj is offline
Daveyj is starting off with a positive reputation.
I know this thread is plenty old, but I'm working with the same fuse box illustrated above, and I'm trying to get my dome light working. My box was missing the fuse in the #7 spot. The diagram says it needs a 15 amp fuse, and thats what I tried to put in, but it doesn't fit. It's about a 1/16 of an inch too long and I can't get it in there for the life of me. I suspect thats why the PO didn't have one in there also. Has anyone else run into this problem?
Old 01-30-2011, 01:08 AM
78 PEB's Avatar
78 PEB 78 PEB is offline
78 PEB is gaining momentum as a positive member of FTE.
There are different lengths of 15A fuses. take the one thats too long into the parts house and have em find the next shorter style.
Old 01-30-2011, 07:26 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Daveyj View Post
I'm trying to get my dome lamp working. My box was missing the fuse in the #7 spot. The diagram says it needs a 15 amp fuse, and thats what I tried to put in, but it doesn't fit.
1973/79 F100/350 15 amp dome lamp fuse industry (autoparts store) numbers. The number is marked on the fuse itself.
1973/77 F100/350: AGW-15 or 7AG-15 / .88" long.
1978/79 F100/350: 1AG-15 / .62" long.
Info source: 1973/79 Ford Light Truck Parts Catalog.
Old 01-30-2011, 03:03 PM
The fuse i bought was the AGW-15 or 7AG-15. Thats the one that is too long.
After further research and the help from the good people here on this site I have determined that i need the 1AG-15.
Unfortunatly none of the parts store that I was able to get to last night here in my area carry that particular style. Of course is was later in the evening so i was only able to get to the Oreily, and autozone places. Tomorrow I'll hit up some of the locally owned stores.
Old 05-18-2012, 04:55 PM
craigc187 craigc187 is offline
craigc187 is starting off with a positive reputation.
slot 1
i dont understand the autozone one but the pictures steponit posted look easy for me but i dont have a fuse on my number 1 either but i tested the slot and one side is live could this be my cruse control i have a 1977 f100 custom 302 v8 c4 tranny if i need it what size is it meant to be?
Old 05-19-2012, 04:26 PM
PapaBearYuma's Avatar
PapaBearYuma PapaBearYuma is online now
PapaBearYuma is gaining momentum as a positive member of FTE.PapaBearYuma is gaining momentum as a positive member of FTE.
Quote:
Cruise (speed) Control should run off fuse number 10. It's 20 amp.
Old 05-20-2012, 01:43 AM
fasthauler's Avatar
fasthauler fasthauler is offline
fasthauler is gaining momentum as a positive member of FTE.
I gave up trying to find those oddball out of date fuses, so below was my solution. The circuit breaker panel is the same dimensions as the old fuse panel and bolts right in using existing screw mounting holes. I was rewiring the truck anyway so the installation of this circuit breaker panel was an easy project. Another simpler solution would be to solder in the ATC inline fuse holders. That way you can use modern fuses. I did have to install one inline fuseholder for F2 as they don't make a 2 amp circuit breaker.
Old 05-27-2012, 04:44 AM
Fuses
Quote:
thank you very much i knew that must of been it so now for sure i don't need it
as my cruise control is broken atm
Old 01-27-2013, 08:22 PM
Worktrucks Worktrucks is offline
Worktrucks is starting off with a positive reputation.
Would the diagram steponit posted be the same for a 74 f250
Old 01-27-2013, 09:34 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
No, a '74 is smaller. Here you go: http://fordification.net/tech/images...aster_1of8.jpg
Old 01-27-2013, 10:24 PM
EffoneHunded's Avatar
EffoneHunded EffoneHunded is offline
EffoneHunded is gaining momentum as a positive member of FTE.EffoneHunded is gaining momentum as a positive member of FTE.
from 1974 owner manual
Fuse problem or just a coincidence? DieselCamper 1973 - 1979 F-100 & Larger F-Series Trucks 7 08-18-2016 06:34 PM
Fusebox replacement 1966 f100 Michaelshawnbradford 1961 - 1966 F-100 & Larger F-Series Trucks 4 02-24-2015 01:59 PM
Picture of fuse box? RazRamon 1961 - 1966 F-100 & Larger F-Series Trucks 3 06-28-2013 10:46 PM
59 F100 fuse box mtdorf Electrical Systems/Wiring 3 10-16-2012 07:55 PM
Fuses beartracks 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-12-2011 11:56 PM
Tags
100, 1973, 1977, 1979, 2007, 79, box, e250, f150, f250, ford, fuse, fuses, panel, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
