Heater Core/Blower Motor Access - Ford Truck Enthusiasts Forums
Old 11-16-2010, 11:45 PM
daningraham's Avatar
daningraham daningraham is offline
daningraham is starting off with a positive reputation.
So my recent wiring misfortunes have forced me to open up the dash and deal with things that I was hoping to deal with later. Nevertheless, I was looking into replacing the blower motor and heater core and it would appear that the assembly that houses it has rusty rivets holding it together? Am I to assume that this has never been cracked open and the heater core is the stock one? I can't figure any other way that it would have been accessed.
Either way, my question is, do I really need to grind the rivets off in order to access these two items? If so, how do I reassemble this when I am done? Do these get replaced with bolts and screws?
Any info here is appreciated.
Old 11-16-2010, 11:56 PM
smokeyb97's Avatar
smokeyb97 smokeyb97 is offline
smokeyb97 is starting off with a positive reputation.
Does your truck have factory a/c?
Old 11-17-2010, 12:05 AM
Quote:
Nope, just the windows.
Old 11-17-2010, 12:31 AM
smokeyb97's Avatar
I thought I might could help, but mine is a factory a/c unit. I replaced the blower motor and heater core and it wasn't fun at all. Yours should be alot easier.
Old 11-17-2010, 12:28 PM
In reviewing other posts on this subject, it sounds like this assembly should be mechanically fastened from the engine compartment, but I couldn't really see how that occurs. Any info would he helpfull. Thanks.
Old 11-17-2010, 01:16 PM
highboy1975 highboy1975 is offline
highboy1975 is starting off with a positive reputation.
i pulled mine out and it had screws holding the heater core cover plate in place. you have to remove that cover to pull the core out. its small, maybe 3x8 in cover for the core.
Old 11-18-2010, 02:14 PM
I got the entire assembly out and removed the heater core and the fan, but I am wondering if there is any way to "freshen up" the flapper valve that directs the air? It appears to be a metal flap with rubber around the edges, but the rubber is pretty chewed up. Do they may replacements for these or do you just have deal with it? Can't find any options on LMC.
Old 11-19-2010, 01:39 PM
three on the tree three on the tree is offline
three on the tree is starting off with a positive reputation.
Hay Smokeyb97.
I have a 78 F150 with factory A/C and need to replace the heater core any tips or items to be warey of would be helpful
Thanks
Old 11-24-2010, 06:58 PM
PRUSue PRUSue is offline
PRUSue is starting off with a positive reputation.
This will sound silly- but how do you get the heater assembly BACK into place after removal? I cannot for the life of me slide it into place, and have been scratching my entire dash trying. There must be only ONE orientation that allows it to fit in? I had the best luck putting the blower motor side in first and can get it into place, but then the rest of the box near the heater core tubes gets caught. ANY HELP?
Old 11-24-2010, 07:33 PM
dave_dj1 dave_dj1 is offline
dave_dj1 is starting off with a positive reputation.
I just put a new heater core in my 79 f150, no ac, I took the glove box out to be able to see better. I also took the little fresh air door off before trying to put it back in. I set it on the floor, tipped the top up in and then rocked it back, being careful not to damage the heater core nipples. The only "snag" was the center bolt that goes through the firewall was the only "hang up" It seems longer than necessary. Good luck.
Old 12-11-2011, 06:26 PM
keith_ashworth keith_ashworth is offline
keith_ashworth is starting off with a positive reputation.
I have a 1975 F-250 High Boy with factory air, 360, and C-6. I accessed the heater coil by removing the air conditioning coil from inside the cab. Once the A/C coil was removed the heater coil is staring right at you and comes straight out. Before removing the A/C coil, I removed the blower; but, could not access the heater coil. Not possible on my truck.
Old 12-11-2011, 07:07 PM
MAULMAUL's Avatar
MAULMAUL MAULMAUL is offline
MAULMAUL is gaining momentum as a positive member of FTE.
Here is a good example of one with factory air.
NORTH COUNTRY SPECIALTIES
I changed the blower motor, from the engine bay Carny 1973 - 1979 F-100 & Larger F-Series Trucks 35 11-01-2016 10:36 AM
1973 F100 Heater Core replacement question onestr8 1973 - 1979 F-100 & Larger F-Series Trucks 12 10-01-2016 10:19 AM
Heater Core Replacement Monana ford Man 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-11-2015 07:48 PM
question about heater core and box 90turbo1 1999 to 2016 Super Duty 0 08-09-2014 02:19 AM
Accessing heater blower motor on A/C equipped truck biggreen4x4 1973 - 1979 F-100 & Larger F-Series Trucks 51 12-16-2003 02:22 PM
Tags
1947, 1978, 79, accessing, assy, blower, bronco, core, f100, ford, heater, motor, replacement, stock, truck, wanted
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
