71 f250 4x4 steering column rebuild some ?
i have the steering column out of my 71 f250 crew cab figured ill rebuild it and put new bearings in while i'm at it. anyone do this and have some pictures to go by? where would the best place be to buy new bearings from what i read the bearings are different then the 2wd vehicles it takes 2 different bearings as opposed to the 2wd with same top and bottom. can you give me a rundown on disassembly and reassembly any tips and tricks you's might have. and will the bearings come right out or do they need some work to get them out to replace? anything else i should replace or do while i have it all torn down? ill be taking pics as i go for future reference along with my heater box restore.
I have the current ford part numbers listed below
Bottom Bearing - F23Z-3517-B - $17.37
Top Bearing - C3DZ-3517-A - $9.28
Top Sleeve - B1AZ-3518-A - $8.80
I do not have the number for the bottom rubber sleeve, I did not replace it because it was not bad.
I hope this helps and just ask if you need more help
Thanks for the reply ill ask if I need any help how do you get the bottom bearing retainer out with a small dentists pick or something? Could you give me a quick rundown of the Power steering install? How long did it take? Any more pics of the box to frame and pump on motor pics you could post up
I just sprayed it with wd-40 and then worked the bearing out. I have posted pictures and some information about the steering swap at another forum. I am going to add more detailed information when I have time to write it up. here's the link to it, hope it helps.
The FORDification.com Forums • View topic - 72 Highboy, Added 78 Power Steering
No it is from a 78 F-250 4WD, it was only used in 78 and 79 and only on the 250/350 4WD trucks. Having only been used for two years, it is not something you find everyday at your local salvage yard. The way to tell it from the others is that it has four mounting holes instead of three and it has the correct pitman arm you need for the drag link. Unlucky for us is the fact that most people that have them know what they have and it can be quite pricey to buy.
hey i got one of those! maybe i shoudl swap it into my 75 so i can get rid of that crap assist
i'll be trying the power steering swap this summer i got the bearings out of the upper and lower part of the column i just need to order new bearings i'll post up some pics of the teardown of the column and rebuilding as i work on it it's a rainy day project as i'm working on the truck outside whenever the weather allows it. anyone know about the body lift? if i add a 3'' body lift will i need to extend the steering shaft or cut and move the column mount that bolts under the dash? or would it work ok how it is?
hey everyone finally got around to posting some progress pics have it all disassembled. i'm going to get the outer housings powder coated while it's apart. can anyone answer my question about adding a 3'' body lift if i need to modify the steering column in any way? need to know this incase i got to do some fabricating before i drop it off to be painted. and just need to buy the bearings i'll get to the dealer next week i hope.
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/?action=view&current=ImportedPhotos00054.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/ImportedPhotos00054.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/?action=view&current=ImportedPhotos00059.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/ImportedPhotos00059.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/?action=view&current=ImportedPhotos00062.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/ImportedPhotos00062.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/?action=view&current=ImportedPhotos00067.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/ImportedPhotos00067.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/?action=view&current=ImportedPhotos00080.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/ImportedPhotos00080.jpg" border="0" alt="Photobucket"></a>
also is there anything else i should do while it's apart or is the bearings all that's needed?
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/?action=view&current=ImportedPhotos00082.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/ImportedPhotos00082.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/?action=view&current=ImportedPhotos00084.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/ImportedPhotos00084.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/?action=view&current=ImportedPhotos00065.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/ImportedPhotos00065.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/?action=view&current=ImportedPhotos00092.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/ImportedPhotos00092.jpg" border="0" alt="Photobucket"></a>
^picture above would you pull that apart inside the wheel for anything? or would you leave it how it is?
<a href="http://s1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/?action=view&current=ImportedPhotos00088.jpg" target="_blank"><img src="http://i1035.photobucket.com/albums/a432/crewcabstripper/crew%20cab%20steering%20column/ImportedPhotos00088.jpg" border="0" alt="Photobucket"></a>
Awesome thanks haven't updated this thread as its still all torn apart and at the powder coaters need to get the parts back. my powder coater had some injuries from a motorcycle wreck shortly after these parts got taken to him then after that he had to move his facility into storage because of a flood so it took him awhile to finally reach my buried parts and should have them back within acouple weeks. Ill update this thread and show the reassembly process I believe I still have my whole tear down process pics if you need any others I may have them just ask and ill see what I have. Ill redo the pics above when I get a chance to.
Part numbers in post 3: Prices different, lower bearing obsolete as is its sleeve (not listed in post 3). tpdaniels got "laid away" on the upper sleeve, cuz it was never $8.80.
C3DZ-3517-A .. Steering Column Bearing / Available from Ford.
Too many 1960/79 car/truck applications to list.
MSRP: $10.68 / FTE sponsor tousleyfordparts.com price: $7.05.
F23Z-3517-B (replaced E1FZ-3517-B, D4TZ-3517-A & B, DOAZ-3517-A, C7SZ-3517-D & C3AZ-3517-A) .. Steering Column Bearing / Obsolete
Misc applications: 1966/76 F100 4WD (lower) / 1967/79 F250 4WD (lower) / 1975/79 F150 4WD (lower) / 1981/97 Escort/Lynx & 1984/95 Tempo/Topaz (upper).
Over 100 available NOS
B1AZ-3518-A .. Steering Column Bearing Sleeve / Available from Ford.
Too many 1951/79 applications to list.
MSRP: $4.85 / tousleyfordparts.com price: $3.20.
C6TZ-3518-A .. Lower Steering Column Bearing Sleeve / Obsolete ~ 4 available NOS
Applications: 1966/72 F100 4WD / 1967/72 F250 4WD
1966 F100 4WD, 1967/75 F100/250 4WD: The lower steering shaft & coupler is the same as is its u-joint (there's only one).
E2HZ-3815-A (replaced C6TZ-3815-B) .. U-Joint / Obsolete ~ Over 185 available NOS as it was also used on 1966/86 C Series Tilt Cabs.
