Wierd PCM issue
11-16-2010, 07:00 PM
on
Wierd PCM issue
Any of you that saw my died and won't restart thread know that I changed my PCM. I used a 1997 PCM, and I did notice a difference in power (more power) But, with this PCM, it goes romp, romp, romp, every time I start it, hot or cold, and it will only quit romping once I give it a little throttle, then its fine. With the original PCM, it would only romp on real cold starts.
I'm confused????
11-16-2010, 07:07 PM
on
Could it be a cali pcm. Could be burned for splits. You might have to get it reflashed.
Is your truck a cali model, was the PCM for a cali model ?
Are you running an ICP mod (10 k) or what ever ?...
11-16-2010, 07:08 PM
on
I win lol
11-16-2010, 08:17 PM
on
A PCM from an automatic truck will do it too. I know. It needs to be reflashed for a 5 speed if you want it to be right.
11-16-2010, 08:40 PM
Quote:
Originally Posted by
RRranch
An auto PCM just ignores the trans ...
11-16-2010, 08:46 PM
on
It is not a cali PCM and my motor is not a cali motor.
I do not have any ICP mods at all. it does the same romp, romp with the ICP unplugged.
It is an auto PCM if that makes any difference...
Thanks guys,
BTW, this 97 PCM will not communicate with my AE, but the old PCM did
11-17-2010, 08:52 AM
on
Any ideas??? It runs way to well for the PCM to be burned for splits.
11-17-2010, 10:37 AM
on
Are any of the pins corroded or dirty. A bad connection on a pin or two?
11-17-2010, 10:50 AM
Check your cigarette lighter fuse.
It powers the OBDII port.
11-17-2010, 11:45 AM
I would bet its cause its an auto pcm. and Auto will do the same thing if the neutral safety switch is bad.
11-17-2010, 12:08 PM
tjbeggs
I have always been told the autos in a 5 speed just ignore trans input , I think it was from Bill ..
BTW , did you hear back from Bill ?..
11-17-2010, 12:17 PM
on
bad12jr
No, I don't think so.
Hussler
I'll check that, but my scanner did the same thing when this PCM was in a different truck.
tjbeggs
This has to be it, because there are no other differences that I know of.
Thanks for the input guys!
11-17-2010, 05:04 PM
Action4478
Not sure on that Rick. Doesn't make sense to me that that would be the case but if Bill says I would believe it.
I have not heard from Bill. You haven't either?
11-17-2010, 05:32 PM
tjbeggs
No ....
honeydew
23
08-19-2013 11:12 AM
bluef72
31
02-20-2013 10:01 PM
alstieg
06-16-2009 09:21 PM
natewoz
10-19-2008 07:52 AM
ChevDog1
16
09-07-2004 03:34 PM
