Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 11-16-2010, 06:45 PM
staysbroken staysbroken is offline
1978 Ford F-100
My Garage
staysbroken is starting off with a positive reputation.
Ignition switch wiring diagram/color coding
Anyone know where I could find a wiring diagram relating to the ignition switch?
When I bought my truck, the previous owner had rigged toggle switches and a push button in place of the ignition switch. So, I just snagged a complete switch and the wiring plug off a '76-ish F150 in a junkyard, and dropped it off with a locksmith to be rekeyed.
  #2 (permalink)
Old 11-16-2010, 06:50 PM
Nathan Plemons Nathan Plemons is offline
1995 Ford F-150
My Garage
Nathan Plemons is starting off with a positive reputation.
Shoot me an e-mail and I'll send you the complete 1974 wiring diagrams. Should be the same switch.
  #3 (permalink)
Old 11-16-2010, 07:05 PM
1978 Ford F-100
My Garage
Email sent, thanks!
  #4 (permalink)
Old 11-16-2010, 07:08 PM
1995 Ford F-150
My Garage
Should be on the way. Hope it helps.
  #5 (permalink)
Old 11-16-2010, 07:16 PM
steponit steponit is offline
Garage is empty, add now
steponit is gaining momentum as a positive member of FTE.
The switch on the 78 is different than previous years
  #6 (permalink)
Old 11-16-2010, 07:25 PM
1978 Ford F-100
My Garage
Yeah, I don't expect it to be completely plug and play, especially since my existing wiring is cut and spliced as much as it is already. I'll be doing a bit of testing with the multimeter to get everything working right
  #7 (permalink)
Old 11-16-2010, 07:29 PM
Click the image to open in full size.
  #8 (permalink)
Old 11-16-2010, 09:11 PM
1978 Ford F-100
My Garage
Thanks guys! Hopefully the locksmith will be done rekeying the thing early tomorrow so I can get to work!
...I cleaned up my under-hood wiring pretty well yesterday and today; tomorrow is time to tackle under the dash!
__________________
1978 F100 For Play... SOLD! 501 stroker, ported Edelbrock Performer RPM heads, ported Performer RPM Air Gap, Comp Cams XE274H
1997 Ranger For Work... 2.3L/T5
1979 Honda CB750K
  #9 (permalink)
Old 11-17-2010, 08:36 AM
1995 Ford F-150
My Garage
I was working on getting my cluster to work and I moved something and I heard the unmistakable sound of something electrical arcing for just a split second. I got to looking around and there was as white wire behind my cluster with a stripped end connected directly to the starter solenoid terminal, otherwise connected to nothing. Glad I ripped that out before it burned the whole truck to the ground.
  #10 (permalink)
Old 11-17-2010, 02:22 PM
Especially since that Yellow 3-way connector is a keyed power source.
  #11 (permalink)
Old 11-18-2010, 08:49 AM
1978 Ford F-100
My Garage
Well, apparently the switch I got was actually from a 78 truck, as the part number started with D8... All I had to do was to match up color to color, and everything works perfectly now! The color coding does match up in the diagrams you guys gave me, but there are several wires in the 78 that apparently were not in the earlier year models.
The locksmith charged me $40 to rekey the lock though, wasn't expecting it to be near that much!
__________________
1979 Honda CB750K
  #12 (permalink)
Old 11-18-2010, 09:05 AM
1995 Ford F-150
My Garage
That that seems a little high, but hey, at least it's working!
Tags
08, 1979, 1995, 1999, 64l, diagram, diagrams, diesel, ford, harness, ignition, schematic, switch, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
