8 lug on a F100
Old 11-15-2010, 09:25 PM
karjunkie's Avatar
karjunkie
karjunkie is offline
Question 8 lug on a F100
Hi fellas, is it possable to go from a 5 lug to 8 lug on a 77 2WD with a 9 axle ?
Old 11-15-2010, 10:38 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
You can, Moser, Strange and others offer 8 lug 9 inch axles...
However, it would be cheaper to just swap in a Dana 60.
Josh
Old 11-16-2010, 02:41 AM
Friesian-Bronco's Avatar
Friesian-Bronco
Friesian-Bronco is offline
Been wondering about this myself, anyone offer a kit for conversion?
Also been thinking of doing a disc brake conversion on a 9", what are the odds of finding 8 lug rotors that would fit?
G.
Friesian-Bronco
double post..
Old 11-16-2010, 07:00 AM
79 f-150 guy's Avatar
79 f-150 guy
79 f-150 guy is offline
i coverted mine to 3/4 ton specs.. mine was a 1979 f-150 2wd, now 3/4 ton 2wd.. it went pretty strait thru, only trouble i ran into was converting the rear from 2.5" wide springs to 3" wide springs. you need to get the spring hangers from your doner truck..
Old 11-16-2010, 08:01 AM
410F-100's Avatar
410F-100
410F-100 is offline
been intrested in this for a while too...
whats the difference between the earlier low pinion d60 and the later high pinion d60??
And a stupid question, how do you tell the d60 from the d44 apart? bolth front and rear... I could probly figure it out on my own, but what could it hurt to ask!
Old 11-16-2010, 08:08 AM
Joseph69's Avatar
Joseph69
Joseph69 is offline
LP60 has pinion at bottom of carrier, closed knuckles behind the spindle and drum brakes. HP60 pinion at top, open knuckles, disc brakes and a 4 inch hub where the lockout is. D44 has a smaller hub.
Old 11-16-2010, 08:09 AM
thndrroad70's Avatar
thndrroad70
thndrroad70 is offline
Although the dana 60 an obviously much larger unit its easy to tell difference if you know them, but look into the forward facing webbing around the front cover there will be a 60 cast into the housing here if its a dana 60 I dont know about the 44s as I have never actually paid much attention to them....
Old 11-16-2010, 08:50 AM
wyckedcombo17's Avatar
wyckedcombo17
wyckedcombo17 is offline
Most fool proof way for determining is the bolts for the inspection cover
Dana 44: 1/2" bolts
Dana 60: 9/16" bolts
Old 11-16-2010, 12:25 PM
79 f-150 guy
ya we were all taking about 2wd trucks..
Old 11-17-2010, 05:30 PM
karjunkie's Avatar
karjunkie
Ya, thats how it started, its all good info !
Old 11-17-2010, 05:58 PM
karjunkie's Avatar
karjunkie
Josh
ok got som ideas bout the rear what bout th front
Old 11-17-2010, 07:19 PM
Bullitt390's Avatar
Bullitt390
Got me there, unless a person swaps in F250 I-beams with spindles.
Josh
Old 11-17-2010, 07:55 PM
Joseph69's Avatar
Joseph69
Joseph69 is offline
Are you planning on towing with the 8 lug? Are you looking for more weight capacity? Are you just looking for a stronger axle for more performance? I had an F100 then swapped the engine into a Crewcab F250, I was surprised at the difference in the frame strength. the 250 has a thicker and overall stronger frame. Putting bigger axle may not increase the weight capacity of the truck itself, you probably wont have any problems until you crack or bend the frame. May be a better option to find an F250 and swap the body.
Old 11-17-2010, 08:48 PM
karjunkie's Avatar
karjunkie
Josh
gosh,never thought it would get this detailed
Quick Reply: 8 lug on a F100
