V10 WATER PUMP REMOVAL - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-16-2010, 05:31 PM
ricksautorestoration ricksautorestoration is offline
ricksautorestoration is starting off with a positive reputation.
My V10 engine in my 97 motorhome threw a connecting rod so i recently removed it. I am in the process of dis-assemby. How in the world do you remove the large nut thats connected to the water pump? My water pump pully turns obviuosly but i did manage to grab a couple of the bolts on the front of the pully with vice grips managed to jam it good and still could not brake the large nut loose? This is LH thread right? I used a large crescent on the nut pounded with a hammer still cant get it to break even tried putting some heat to it? Is there something i'm missing? I mangaed to un bolt the pump from the engine but i still need to get the clutch fan and pulley off for my new engine. Maybe i will have more luck putting it in a vice now but still want to be sure this is LH thread. Thanks to anyone that may be able to help me out.
Old 11-16-2010, 06:15 PM
nitrogen's Avatar
nitrogen nitrogen is online now
nitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant future
try a chain vise grips around the pulley(use a length of the old belt to protect the pulley) then a long wrench on the nut and wack it good, with a BFH. 5 pounder. as far as the direction of thread some use a left an some use a right, I'm not personlly familiar enough to say
Old 11-17-2010, 02:51 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
That big nut can get VERY stuck over time! I do recall it being a standard thread. Soaking it with PB Blaster or another good penetrating oil is a HUGE help.
I made my own version of the factory tool - it is basically a "pitchfork" where the legs fit around the 4 bolts on the front of the fan. If you have it out now, maybe you can clamp those bolts in a vise?
"Professionals" very frequently use an pnuematic hammer with a chisel bit. Set the chisel near the peak of the hex and hammer at an angle. Makes a mess of the nut, of course, but will break them loose very quickly.
What a PITFA IHateCommieCars 6.0L Power Stroke Diesel 63 06-29-2015 06:27 PM
Water pump question cyris426 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-31-2014 08:09 AM
fan, water pump remopval 85 f150 mattthegreat 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 10-25-2013 06:06 PM
Water Pump pullys (Decode numbers) Bill W 1961 - 1966 F-100 & Larger F-Series Trucks 7 03-31-2007 12:12 PM
Help with 1993 Power steering pump pully khab 1987 - 1996 F150 & Larger F-Series Trucks 6 10-12-2002 09:05 PM
Tags
10, 1999, 450, 68l, 73, 92, diesal, f250, ford, pulley, pump, removal, removial, rremove, v10, water, waterpump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
