Bed Bolts from HELL! Help
i don't know if i'd want to weld them to the bed. the bed is only sheetmetal and it'd be a lot more grinding once you get the nuts off anyway.
remember to put anti-seize on them when you put them back on.
when i put mine back in i left the nut welded to the head of the bolt so i could tighten them. once the bed was installed and the bolts tight i then grinded off the nuts. once finished i sprayed the heads with duplicolor bed undercoat.
The only problem with this method is it will damage your bed when you grind them off so if your planning on keeping the bed you might want to shy away from that idea. I have done this a bunch of times and the best way that worked for me was to tack them to the bed with a small weld and use an impact to zip em off. When I was done I used a grinder and removed the tack weld and coated the bed and no one could ever tell I did it that way.
I tried the welding a nut to the top of the bolt, but my welding skills failed me. We ended up grinding the head off the bolts, punching them down into the bed, jacking up which ever corner of the bed 1/2 inch, and cut the bolts inbetween the bed and the frame with a saw-zall (Spelling on saw-zall?). All were good ideas, thanks for all the advise. I plan on putting the bed back on using hardware that is used on 2005-newer Superduties. Round headed bolts with hex head inserts, and on the frame is a threaded clip, so all you do is loosen from the top side.
(PS: Don't laugh at me 'cause it took longer to get the bed off than it did the entire front clip of my truck... ;-)
how well did you clean up the bolt heads? I hit them with the angle grinder first to make sure i was welding to good clean metal. my dad is a rookie welder and we used a simple little tiny welder and only tacked them in a few spots and the welds held fine. I can't believe you weren't able to weld the nut.
quality1construction
11-01-2013 03:43 PM
