cruise control does not work - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-16-2010, 04:42 PM
ronjon95's Avatar
ronjon95 ronjon95 is offline
ronjon95 is gaining momentum as a positive member of FTE.
Recently the cruise control stopped working. Thinking that maybe the recall would repair this issue it has not. I have checked fuses several times and all are good. I tried getting info from Haynes manual and a DVD from a Ford service manual that was purchased on e-bay but has no dignosis lititure on this. Could you guys help me out?
Old 11-16-2010, 05:00 PM
orng1's Avatar
orng1 orng1 is offline
orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.
Does yours have the update done? Mine worked fine then after they did it it stopped working.
Old 11-16-2010, 05:04 PM
ronjon95's Avatar
Update? Do you mean recall yes had it done today. It stopped working before this. Thought it would fix the issue.
Old 11-16-2010, 07:07 PM
ronjon95's Avatar
Arrow
Can someone please help I got a 2 hr. drive Friday to Cinci Ohio would really like to have cruise. Just getting it back to the top.
Old 11-16-2010, 08:04 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Mine quit and it was the speedo sender on the rear axle.
$20.00 part.
Old 11-17-2010, 06:08 AM
ronjon95's Avatar
This speed sensor, would your speed MPH gauge not work if this sensor was bad? Because this gauge does work.
Old 11-17-2010, 06:16 AM
dadsgreenpsd's Avatar
dadsgreenpsd dadsgreenpsd is offline
dadsgreenpsd is gaining momentum as a positive member of FTE.
Auto or standard? If standard, check the clutch pedal switch.
Old 11-17-2010, 06:19 AM
ronjon95's Avatar
Standard 6-speed. If this switch was bad the truck would not wont to start. I have a AE could this tell me anything?
Old 11-17-2010, 06:50 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Yes you could run a switch test with AE, but I'm willing to bet it's the CPP (clutch pedal position) switch. You can pick one up at the local parts store pretty reasonable. The worn springs won't keep the truck from starting.
Go ahead and pull it out and look inside there. Do you see one long spring on each side, or what appears to be multiple springs stacked on each other or broken like this
Old 11-17-2010, 07:01 AM
ronjon95's Avatar
Ok guys I fell like where going around in circles here. The Cruise Control (Speed Control) does not work the truck starts fine the MPH gauge and RPM gauge works fine. Your telling me that these sensors are causing the problem or one of them.
Old 11-17-2010, 08:16 AM
brownie83's Avatar
brownie83 brownie83 is offline
brownie83 has a very good reputation on FTE.brownie83 has a very good reputation on FTE.brownie83 has a very good reputation on FTE.
i had the SAME problem...starts fine, ran fine...it was the clutch pedal switch. the part is like 80 plus dollars from ford, so i just made jumper wires and connected them to the connectors. there are 4 connections, if i remember, the first 2 get hooked together and the last 2 get hooked together.
NOTE: the truck will NOW START WITHOUT THE CLUTCH DEPESSED. make sure you depress the clutch or put the truck in neutral.
i have also heard that the 3rd brake lite being burned out could cause a no cruise condition. no positive about this, but jim rat49f6 told me it happens.
good luck
Old 11-17-2010, 04:24 PM
Quote:
Not necessarily. I have replaced mine 3 times (i used to have a windshield leak, which ruined them) and it would always start, but I could tell it was time to replace it when it either dropped out of cruise, or would not engage cruise.
Hope you find the problem!
Old 11-17-2010, 04:59 PM
robs01f250 robs01f250 is offline
robs01f250 is gaining momentum as a positive member of FTE.
the rod that connects to my clutch pedal and runs through the firewall came off one time and now my cruise control wont work.
Old 11-17-2010, 06:08 PM
ronjon95's Avatar
Ok thanks guys I understand now. It was just a little vage for me why it could be the switch make since know depress clutch pedal shuts off high idel and cruise. Duh on it right know to have a look see.
Old 11-17-2010, 07:14 PM
F350-6's Avatar
Quote:
That's where the sensor we're talking about sits. Right on that rod next to the firewall. Sounds like you should check yours too.
Adaptive cruise control and trailering DDT11 2017 Super Duty 7 09-07-2016 05:20 AM
2006 Expy cruise control schematic diagram Domino Expedition & Navigator 2 03-27-2015 04:15 PM
Cruise Control working intermittent 540milotalon 1994.5 - 1997 7.3L Power Stroke Diesel 4 06-29-2011 09:51 PM
Trouble shoot the cruise control Jaaaaaaackman 1994.5 - 1997 7.3L Power Stroke Diesel 4 09-21-2007 10:33 PM
Cruise control speed sensor on ZF5 Dieseldan7.3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 01-16-2006 05:33 AM
Tags
03, 1997, 2001, 73, control, cruise, f250, f350, ford, sport, trac, truck, trucks, wont, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
