Duraspark II Wiring Harness..??
#31
This is for the Tach feed, there is a matching connector for this, if you do not have a tach it really does not matter.
I have not seen a harness with 4 red wires before.
Do you have a V8 or I6 engine?
Jim
#32
4 Red Wires
this rebuild 460 was in a 1981 Bronco which I am installing in to 1995 F-250 with 5.8L fuel injected engine. From an old Bronco schematic the four wires go to the ignition switch. There are two wires that are RED and one that is RED/2 wht strips and one with one wht strip? But what pin thy go on I do not know. The schematic says pin #4, #5 but wiring harnes has no numbers.
#34
dyingtolive
297
05-24-2021 09:15 PM
reamer
07-09-2017 12:08 PM
pd59
13
02-20-2012 03:34 PM
sunnyb
20
07-07-2010 01:05 PM
ClatonK
Electrical Systems/Wiring
01-04-2004 03:51 AM
