I just finished a head gasket job. Finally started the truck, she ran bad for a while then leveled out. But my injectors are leaking bad and i still have white smoke. All i did was but new copper washer on it since it came in the new gasket set. what should i do?
Did you replace the o-rings under the plastic caps when you replaced the injectors?
If not, they are leaking and need to be replaced. Do a search on return lines and you'll find a million responses on how to replace them.
when the return lines are disturbed they will start to leak the o-rings get brittle and will eventually not seal.when you change injectors you should always put a return line kit on,if nothing else go get a couple dozen #111 viton orings and toss the old ones.when you reinstall the caps make sure they are seated properly ,i always use vasaline on the orings before i slide the caps back on
napa has a injeter kit with orings and return lines and clamps, i would say its you rubber o rings, myn would need a set like every year! kit at napa is like 100 bucks but got every thing you need
Double copper washers or no copper washer. Pull one and let us know. I have seen that first hand and it will do it both ways. If you arent step by step sometimes things get forgotten about.
wow that is good, i have seen them on ebay , but never tryed them, i think ill start! lol thanks man
Their gold return line clamps leave a lot to be desired, i would have some good ones on standby. seem to bend and deform often. Also if youre in canada, its 20 bucks freight for shipping so 39 in total. If you have a local place that sells them for 50 or less, i would go there.
