1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Fuel Tank overflow :(
Old 11-16-2010, 01:06 PM
Battman76's Avatar
Battman76
Battman76 is offline
I've recently bought a 02 F250 7.3. Awesome truck, but I have a problem with the fuel tank overflowing. If I fill it full (untill fuel pump shuts off automatically) it leaks diesel fuel all over the tank and eventually all over where I park it. Not a huge deal, but would like to correct it if possible.
I tried to look at the top of it for how the breather etc is setup but it's tough to make heads or tails of that top side without dropping it. Its the large single 30+ gallon tank.
Should I expect this to happen or is something not right? Just wondering if anyone has some wisdom that has had one down before?
Any help is greatly appreciated.
Old 11-16-2010, 01:44 PM
bpounds's Avatar
bpounds
bpounds is offline
First, it is definitely not right. They don't leak when full.
It can leak in several place. First is a torn or displaced vent hose. Next is a torn or displaced fill hose. Last is the large bung nut that retains the sending unit. You might be able to feel for the vent hoses. There is one toward the front and one toward the rear of the tank, in each raised bubble area. Those are the most likely issue. You can usually see the fill and overfill vent connections, so you might rule those out just by looking. There isn't much you can do about the bung nut without either dropping the tank or lifting the bed. Unless you have a camper or other stuff in the bed to complicate matters, I would lift the bed. That way you can inspect the top of the tank just as it sits in the hangers. Otherwise, you can drop the tank and do the same thing.
Last thing I can think of is a cracked tank or fitting. Not likely on those.
Here are some pictures to show what you are getting in to.
Powerstroke Fuel Tank Modification
Old 11-16-2010, 02:00 PM
Battman76's Avatar
Battman76
wow, ive changed a few tanks before, but cant believe you'd lift the bed over dropping a tank. Is it really easier?
Old 11-16-2010, 02:36 PM
acf6's Avatar
acf6
acf6 is offline
One of my friends did it he said it took them 3 guys and was a lot easier than expected
Old 11-16-2010, 02:41 PM
GUNNERDOG's Avatar
GUNNERDOG
GUNNERDOG is offline
Just a word of caution, the bed bolts are notoriously difficult to remove, and if you have to cut them off, the bolts and clips are unusually expensive from the dealer.
Old 11-16-2010, 04:04 PM
bpounds's Avatar
bpounds
bpounds is offline
The nice thing about lifting the bed, is that you can easily look for the source of the leak and see evidence. If you drop the tank you will have to reach up over the top and disconnect hoses and electrical, and that may make it harder to figure out. On the other hand, you might feel the cracked hose right away. But it is not a big job either way, lift it or drop it.
Old 11-16-2010, 06:20 PM
dakotajeep's Avatar
dakotajeep
dakotajeep is offline
I agree that removing the bed is easier.
I did it 5 plus times on my last truck. Dropped the tanks only once and swore to NEVER do it again.
Thad
Deuce40s
11-23-2014 04:22 PM
reddhawk
Escape & Escape Hybrid
01-07-2013 10:06 PM
Dead Meat
10-06-2009 12:52 PM
Fishallot
1978 - 1996 Big Bronco
05-22-2006 12:41 AM
300ci_till_I_die
17
06-20-2002 12:48 PM
Quick Reply: Fuel Tank overflow :(
