Loud turbo "scream" when spooling over normal turbo whistle - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-16-2010, 09:45 AM
Mitch1407's Avatar
Mitch1407 Mitch1407 is offline
Mitch1407 is starting off with a positive reputation.
Hello,
This is my first post on this website. I have been a fan of this website since I had my blood swapped out with diesel fuel when I got my F350. This past weekend I decided to fix a "Skip" that was bugging me that developed a few weeks back. Took it to the dealer and they said new injector o-rings. I changed them, along with the turbo pedestal seals that they also recommended replacing due to an oil leak. Everything is working really well as far as the skip being gone.
However, when I spool the turbo it has a loud scream to it, it seems like if I keep spooling it it will blow off a tube or explode itself. Currently I am at college and plan to tackle this problem in a week during Thanksgiving break.
I have heard of overtightened intake hose clamps causing this "squeal" or "scream" sound.
Seems like me fixing one problem has cause another.
Thanks for any input you all have for my truck, currently driving my dads old 1990 F150 gasser and having diesel withdraws!
Old 11-16-2010, 09:59 AM
Wayne64SS's Avatar
Wayne64SS Wayne64SS is offline
Wayne64SS is starting off with a positive reputation.
sounds like a boost leak to me man. you're on the money with your train of thought. just pull the spider & all boots back off, clean everything, and put together again.
Old 11-16-2010, 10:04 AM
Mitch1407's Avatar
Thanks for replying so fast!
Old 11-16-2010, 10:20 AM
stangclassic66 stangclassic66 is offline
stangclassic66 is starting off with a positive reputation.
Does it kind of sound metal to metal?
Old 11-16-2010, 11:14 AM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
Quote:
We might be on the same line of thought here.....
Take off your intake to the turbo and you van check to see if the bearings are still good and the condition of your turbo. You may get a tiny bit of play but the main thing is that it isn't touching the housing at all. Only takes a few minutes to get in there to check it. As for the boots, I don't know what the torque specs are for them but check the boots themselves. Look for cuts and tears where the clamps are and in the middle. Take them off, clean them and look closely. A small hole can make some noise and get bigger as pressure runs through it.
Old 11-16-2010, 01:14 PM
Wayne64SS's Avatar
being as he was just in there im gonna stay with boost leak.
Old 11-16-2010, 01:21 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
Boost leak would be my first suspect. The X recently had a leak at plenum to head - it sounded like a cat in a blender! Troubling part was it didn't do it all the time, sometimes still making 25psi... After it leaked for awhile, I finally saw the stains at the boot where leak was. Tightened clamp and problem solved - I was sure the 240k turbo was about to check out though...
Old 11-16-2010, 02:50 PM
Yes, mine sounds like a cat screaming for dear life as he's sucked into the turbo... kind of like a sssss-sssss-sssss-ssssssssssssssssssssssssss really fast.
Old 11-16-2010, 07:33 PM
Mitch1407's Avatar
Yeah, I definitely think its a boost leak because it sounds more like a loud air horn than metal to metal and when i was in the turbo last weekend I spun the wheel just to feel how the bearing was, it felt fine.
Another thing is that the little rod that is connected to the EBPV butterfly was a little bent. If the butterfly is not completely straight, could it make this weird sound?
Old 11-25-2010, 08:56 PM
Mitch1407's Avatar
It was a boost leak! The passenger side boot going from the spider to the engine was loose.
Thanks for the input!
Old 11-26-2010, 07:35 AM
Awesome!! Glad ya got it figured out!
Old 11-26-2010, 07:42 AM
Skip1970's Avatar
Skip1970 Skip1970 is online now
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
anyone got a video of this sound? mine wistles, but makes like a weird growl at high b0ost. it hisses at me when i let off the gas too.
Old 11-26-2010, 07:56 AM
nookiemonster55 nookiemonster55 is offline
nookiemonster55 is starting off with a positive reputation.
HUMMM NEVER SUCKED A CAT THROUGH A TURBO...KEEN IDEA!! WILL TRY THIS WEEKEND!
seeing as my wife has 5 of 'em!!
How did the rock climbing go yesterday Jason?
Old 11-26-2010, 10:17 AM
As rewarding as that experiment may be, I'm sure wifey will notice...
We had a blast, I'll post a couple pics in the GTG thread!
06 6.0 INTERMITTENT TURBO PROBLEM chrisbrady498 6.0L Power Stroke Diesel 1 12-14-2015 02:19 PM
2011 Ranger Auto Trans Question Frdtrknut Ranger & B-Series 7 11-08-2015 10:31 AM
'04 6.0L Excursion - Lag problem - turbo won't always spool Bar B Q Excursion - King of SUVs 6 02-22-2015 07:34 PM
Turbo staying spooled? Fameus 1994.5 - 1997 7.3L Power Stroke Diesel 7 01-18-2015 11:23 AM
Turbo Spooling chi6488 6.4L Power Stroke Diesel 16 07-28-2009 09:35 PM
Tags
2004, 60l, 73, diesel, f350, ford, idle, loud, mitch1407, normal, psst, scream, spooling, sucking, turbo, whistle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
