2003 Explorer Engine Replacement
Despite a good preventative maintenance program, the engine on my 2003 Ford Explorer went out at about 185,000 miles. (It appears that the cause of the problem was an overheating issue that was not addressed by the driver who was in a hurry to get to work on time.)
I have studied my options and I believe the best option is to replace the engine.
Before I start the project, I would greatly value any wisdom from the knowledgeable readers of this board. Here are some of the questions that I am considering:
Where is the best place to get the replacement engine, should I buy a used engine or a rebuilt engine, short-block or long-block?
What specialty tools are needed, or would expedite, this job?
Which manual provides the best instruction for guiding me through this process?
What matters am I not considering?
Thank you in advance for your thoughtful consideration.
If your intentions are to keep this vehicle, my advice would be to install a rebuilt long block.
This will provide you with a warranty and minimal installation work.
I cannot recommend a supplier as I do not know where you are located.
Here is an example of prices. https://www.sandjengines.com/ShowAut...PLORER+&Type=8
jprez1980
08-05-2017 08:48 AM
Mcrafty1
10-17-2016 11:40 AM
danno73
1997-2006 Expedition & Navigator
01-29-2013 10:28 PM
nolikecarpayments
12-23-2012 09:17 AM
