pitman arm nut and washer
Ok, need some advice. I have an F150 1995. The power steering gearbox literally rusted through and wouldn't hold fluid at all. So I went ahead and took it out, after much pain and suffering, and I mean alot of pain and suffering, and attempted to remove the nut holding the pitman arm on. Couldn't break it loose on the truck, so figured I could clamp it in my vice and get it off that way. Wrong. Soaked it in penetrating oil overnight. Wouldn't budge. 3 ft bar on a 1/2" breaker bar, nothing. Heat and the 3ft bar, zilch. Finally gave up, and preceded to cut the nut off since cutting the shaft may have been an issue on the core exchange, wasn't sure, just figured the nut was the best choice to cut, I could pick up a replacement. Figured it might be a dealer part but still, thought I would be fine. Wrong again, dealer said its obsolete. Did an internet search and couldn't find it listed anywhere. I don't have time or the desire to find a junkyard and have to screw around removing it from a truck or have someone tell me they won't sell just a nut and washer. Any suggestions where I can find one quickly and painlessly? It is a big dude, 1 5/16" socket
You might try Bronco Graveyard. I found this listing: Nut and Washer
I would suggest you give them a call to verify that is the correct part.
Encho
1978 - 1996 Big Bronco
42
06-05-2021 04:42 PM
the gruffalo
18
09-08-2015 01:00 AM
