Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-15-2010, 09:14 PM
kvolland kvolland is offline
Garage is empty, add now
kvolland is starting off with a positive reputation.
Loss of Electrical Power
I have a 1979 F250 4WD. I recently drove the truck with no issues and after shutting it off and going to restart I got the clicking sound most common to a dead battery. I took the battery and had it checked and charged and everything was ok. Because I had a spare starter relay I swapped it out. Then deciding there was a starter issue I pulled and replaced it after it tested bad. None of this has helped. Fusible link tests good. I have no power at all to normal functions, dash lights and guages, headlights etc. I am at a loss. I am guessing a ground issue, but have not been able to trace the issue. Any thougts would be appreciated.
  #2 (permalink)
Old 11-15-2010, 11:47 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Thread Hijacker
2006 Ford F-250
My Garage
Bullitt390 has a great reputation on FTE.Bullitt390 has a great reputation on FTE.Bullitt390 has a great reputation on FTE.Bullitt390 has a great reputation on FTE.Bullitt390 has a great reputation on FTE.Bullitt390 has a great reputation on FTE.
Check the main wiring harness plug located about where the solenoid is. Should contain a thick Black/Yellow wire which is the main power wire.
Josh
__________________
2006 F250 XLT 6.0 PowerStroke Diesel 4X4: Muffler/Cat/Stealth EGR delete Looney Tune BFG Rugged Terrain tires Blue Spring Mod Upgraded STC Rotella ELC DASHBOSS iPhone monitor
  #3 (permalink)
Old 11-16-2010, 08:29 AM
Nathan Plemons Nathan Plemons is offline
1995 Ford F-150
My Garage
Nathan Plemons is starting off with a positive reputation.
Quote:
Josh
Agreed! The front portion of my wiring harness was butchered up pretty bad on my truck when I first bought it. I bought a much cleaner one from a forum member here and installed it. Everything worked fine until I tried to start the truck. I got one click and then pretty much complete electrical failure, not even the headlights worked. To help me figure it out I turned on the lights and started plugging and unplugging until the lights came on. Turns out it was the same plug that Bullitt is talking about. I took some pliers and carefully tightened up the female ends of the terminals on both ends. I actually did that for all of the plugs and coated them all up with dielectric grease and haven't had a problem since.
Sounds like you've got a circuit that is just barely making contact. It makes up enough to power a small load but when you throw the starter current across it, it's opening up. Electrical gremlins, gotta love 'em!
Tags
2009, click, electrical, f150, ford, loss, power, solenoid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
