Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Crossovers
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
  #1 (permalink)
Old 11-15-2010, 10:50 AM
jdman1 jdman1 is offline
Garage is empty, add now
jdman1 is starting off with a positive reputation.
2005 Freestyle coolant leak.
I was changing my oil last night and notice coolant dripping. As I stand looking at the motor it was coming from the right side(drivers). It looks like the water pump(think thats what it is) between the motor and air cleaner. There is a round 1 1/2 inch connection to the motor and seems to be leaking there. First off, is that what this is if not what is it called? Then, is it a big deal to replace this myself?
Thanks!
__________________
1997 F350 7.3 4x4 CC LB Auto
SuperChip
Tymare intake
Intercooler
3"down & nothing but 4" out the back
  #2 (permalink)
Old 11-16-2010, 07:50 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a good reputation on FTE.70f100longbed has a good reputation on FTE.
Yep thats the water pump. Its not hard to change there are 3 bolts that hold it to the head, one bolt that holds the impeller to the cam, and 2 bolts (I think) that hold the pipe to the pump. Then there is a hose at the bottom.
__________________
Ford senior master tech
Every 5.4 3V owner should have Lisle tool #65600
  #3 (permalink)
Old 01-04-2011, 02:25 PM
So sounds like not a big deal to replace. Is there just a gasket/seal that the pump connects to the head? The bolds that holds the pump on just pushes pressure onto the seal on the head?
thanks!
__________________
SuperChip
Tymare intake
Intercooler
Tags
2005, antifreeze, coolant, engine, f250, ford, freestar, freestyle, heating, intake, leak, leaking, leaks, system, water, waterpump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
