Injector Wiring Harness $109.99 - Ford Truck Enthusiasts Forums
Old 11-15-2010, 08:57 AM
hubler13f's Avatar
hubler13f hubler13f is offline
hubler13f has a good reputation on FTE.hubler13f has a good reputation on FTE.
I tore my truck down this weekend and found that my injector wiring harness was all jacked up at the FICM connectors.
They were so brittle that the connector housings came apart in 3 pieces, one piece stuck in the FICM and had to be removed with some needle nose pliers.The pins and wires were exposed. I used a plastic epoxy to try to put it back together, but it turned out pretty crappy.
Needless to say my truck ran like crap when I put it back together. No codes but I had a blown FICM fuse and the truck still ran like crap when I replaced it.
So thinking that that harness is most likely the culprit I started searching for an injector harness and found a guy on ebay that has a pile of brand new harnesses for $109.99. I thought that was a pretty good deal and I know connectors break easily, so I figured I would let y'all know about it.
I don't know where this guy got them, and I hope that they are not stolen, but I'm not askin any questions.
Here's the links to his sales:
NEW 03-07 FORD 6.0 DIESEL INJECTOR HARNESS SAVE $300: eBay Motors (item 190451202876 end time Nov-29-10 19:09:01 PST)
NEW 03-07 FORD 6.0 DIESEL INJECTOR HARNESS SAVE $300 - eBay (item 170548207619 end time Dec-02-10 04:05:53 PST)
Old 11-15-2010, 12:11 PM
rocky1074's Avatar
rocky1074 rocky1074 is offline
rocky1074 is gaining momentum as a positive member of FTE.rocky1074 is gaining momentum as a positive member of FTE.
I would check with www.partsguyed.com who is a Sponsor here on FTE I just check his site for FICM Harness part # 3C3Z9D930AA and it's 70.87
Old 11-15-2010, 08:26 PM
hubler13f's Avatar
Quote:
I couldn't find it on his sight. I don't doubt he has it on there though. I guess it's not such a good deal then. Oh well, thanks for the heads up, I'll be sure to check his sight first from now on.
Old 11-15-2010, 09:33 PM
rocky1074's Avatar
Quote:
When you go to his page www.partsguyed.com scroll down to
Search by Part Number or Keyword put in part number 3C3Z-9D930-AA than select make FORD than Search
You can also send him a pm what you need. Give him Year; Model & VIN he will get back to you with info http://www.ford-trucks.com/forums/pr...newpm&u=311089
I deal with Ed all the time..Great Guy
Old 11-16-2010, 05:27 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
ah shucks........
greenie for you....
Old 12-28-2010, 11:24 PM
Vindicator Vindicator is offline
Vindicator is starting off with a positive reputation.
There was an updated injector harness to reduce chaffing. I saw the part number in a TSB. I have no idea what it looks like, but its double the price of the original harness. Its part # 4C3Z9D930AA. Maybe Ed can chime in and tell us what the difference is.
Old 12-29-2010, 12:10 PM
Former Vendor
2003
3C3Z9D930AA Jumper from 12B637 to fuel injectors. Engine Serial #'s 6030201 and after. NOTE: Prior 1/30/03, 9D930 not servicved separately, part of 12B637 engine harness. Clip for harness to fuel injector retention is part # W301222, Injector Harness, Navistar # 1843796C9*, FROM 1/30/03, 2003 ; 6.0 8 Cyl
2004
4C3Z9D930AA Fuel Injector jumper harness, from 12B637 to Fuel Injectors. NOTE: Clip for 9D930 harness retention to fuel injectors is part # W301222 After 12/01/03, Navistar # 1844137C9*, 2004 ; 6.0 8 Cyl, Ford 250 Series
Old 12-29-2010, 02:48 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is online now
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Have to watch those Ebay deals, sometimes you end paying more than if you bought from the dealer or Ed in this case.
Best pre-packaged CCV kit? Tampa250 6.0L Power Stroke Diesel 8 05-10-2011 09:38 PM
Fuel Reg O-Ring Kit smokersteve 6.0L Power Stroke Diesel 43 02-24-2011 09:36 AM
Digital Dash Riderman 1973 - 1979 F-100 & Larger F-Series Trucks 12 02-22-2011 03:22 PM
1970 HID Conversion kit shephard199 1967 - 1972 F-100 & Larger F-Series Trucks 15 12-02-2010 08:39 PM
used lift kits parts on ebay, cheap jt371 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 11-16-2010 06:51 PM
Tags
3c3z9d930aa, 60, 60l, clips, diesel, f250, f350, ficm, ford, harness, harnesses, injector, powerstroke, specializing, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
