Rear window struts - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Rear window struts
Old 11-15-2010, 12:30 AM
XbigXredX XbigXredX is offline
XbigXredX is gaining momentum as a positive member of FTE.
Rear window struts
Hi all,
Anyone know how to get the struts off the rear window of a 2002 excursion?
Thanks!
Old 11-15-2010, 01:53 AM
ford_model'a''s Avatar
ford_model'a' ford_model'a' is offline
ford_model'a' is gaining momentum as a positive member of FTE.
Yes. You can use a small screwdriver to pry the spring like clip at each end of the gas spring. As you lift or pry the clip out and away from the ball joint connection you will be able to pull the strut off the ball end on the hatch or door frame. Both ends are similar.
Just a note about these struts if you have a 4X4 and you would like the hatch to open a little higher, say 4 or 5 inches you can order the struts meant for the two wheel drive Excursion from Ford.
Old 11-15-2010, 08:48 AM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
Be careful when you remove them. Hold the window up with one hand while you remove the strut one at a time. When you pull one strut out, the window will fall down on your head if you don't support it. One strut is not strong enough to support it.
It's best to have some other person hold it for you. Good luck.
Old 11-15-2010, 09:24 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
Amen on it's heavy !!!!
I used a 2x4 for support when I replaced mine....
Old 11-15-2010, 12:24 PM
TXSailor's Avatar
TXSailor TXSailor is offline
TXSailor has a good reputation on FTE.TXSailor has a good reputation on FTE.
Replaced mine on the 4X4 wiht the longer ones (for the 2WD version) last Fridayl. Much better. That glas is HEAVY to be careful.
Also I've bee having "door open" indicator issues with the liftgate switch whic his in the latch on the Driver side. I solved the probme wiht a bit of WD-40 sprayed on the latch from inside and then adjusting the latch bar on the truck. Makes for a solid fit now and no more "Door Open" light!!!
If your gets flackey, ajdust the latch first as the rubber gaskets taek a set "crushed" in the colder weather.
D
Old 11-16-2010, 04:37 PM
As always everyone thanks for all the help!
I have to ask, because people are calling me "ridiculous" when I offer my opinion as to why there would be different struts for the 2 wheel and 4 wheel version.
So why on G-d's green earth did they make different rear window struts for the 2 wheel and 4 wheel versions?
Oh in case anyone here would like to call me ridiculous, I said "They likely made two versions as the 2 wheel drive sits lower than the 4 wheel drive which necessitates having the rear hatch go up higher or it would hit the average person in the head even open." Seemed 100% reasonable to me.... but others say "RIDICULOUS!"
Old 11-16-2010, 04:43 PM
Dan Reinbold Dan Reinbold is offline
Dan Reinbold is gaining momentum as a positive member of FTE.Dan Reinbold is gaining momentum as a positive member of FTE.
As for the two different sizes, the height of the vehicle 2wd vs. 4wd is the reason I was told and the only reason I can think of.
Old 11-16-2010, 04:56 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
4wd struts might be shorter so the open liftgate doesn't
hit the celing in a typical 7' garage - or be too tall for the standard
soccer mom to reach.
Just speculating..
Old 11-17-2010, 10:06 AM
TXSailor's Avatar
The 4WD Strong Arms are shorter to keep the "open height" (when measured from the ground) close to the same as when the 2WD liftgate is opened.
My wife is only 5' 2" and since i changed the Strong Arms out for the lonre ones on myu 4WD, she has to tippy-toe or jump to reach the handle when the lift-gate is open now.
But at leat it does not hit me in the head now!!!!!
D
Old 11-17-2010, 10:57 AM
So I am correct that the 2wd drive Excursion sits lower to the ground, or that the 4 wheel drive sits higher, whichever way you want to look at it.
I can't find any specifications that indicate this, but I kind of presumed it would make sense.
And making them open higher sounds good to me as I constantly hit my head on them now.
To the guys that did the change, any idea how much higher it is now? 3-4 inches or is it more?
Old 11-17-2010, 12:02 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
Here's a video Mike did over here on an Excursion tailgate. It'll give you an idea on how the glass ones pop off too.
We carry the Ford Excursion tailgate struts
Hope this helps,
Tony
YouTube - 1AAuto.com Install Replace Tailgate Lift Support Strut Ford Expedition 1997-02
__________________
Like us on Facebook
SHOP HERE FOR AWESOME BRAKE PAD AND ROTOR KITS - FREE SHIPPING
Old 11-17-2010, 01:04 PM
AWESOME!
That's all I can say, that video couldn't show it any simpler!
Just AWESOME!
Old 11-29-2010, 05:46 AM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
wow great video! that guy in it looks crazy! i need to get the 2wd ones!
anyone know the partnumber for the 2wd versions?
Old 11-29-2010, 06:44 AM
fordboy67's Avatar
fordboy67 fordboy67 is offline
fordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant future
As stated earlier, once I replaced mine with the two wheel drive versions, my wife couldn't reach the hatch anymore, she has to stand on the hitch to reach it.
Old 11-29-2010, 10:10 AM
jdadamsjr's Avatar
You can fix that by adding a simple leather strap that hangs down from the liftgate, or buy one from another vehicle ...
Your wife will love you again !
Rear Glass Lift Support Struts GVA888 Expedition & Navigator 1 08-11-2012 09:19 AM
Rear shocks/struts replacement? berry1234 2007 - 2014 Expedition & Navigator 5 08-11-2011 06:00 PM
Rear Window Lift Gate Issues... epfire#233 Excursion - King of SUVs 12 01-21-2011 08:26 AM
2001 Expy lift gate & window gas struts scholzee Expedition & Navigator 3 03-23-2009 06:56 PM
Shock vs. Strut? kne831 Aerostar 6 10-10-2006 01:52 AM
Tags
2000, 2wd, 4wd, adjust, excursion, ford, gas, glass, hatch, lift, rear, shock, struts, support, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
