Largest tires to throw under my stock '93 F-150?
I've got 235/75/15 Cooper Discoverer S/T's right now but they just look tiny in my wheel wells.
I'm thinking of going to a true 31"x10.5" Cooper ATR or S/T but I'd like to go a bit bigger if I can. I've heard you can go to a true 32" tire on a stock F-150 but I'm not sure.
I have all new suspension parts and would like to not have to buy anything new, including wheels.
What's the biggest size you have on your stock F-150?
Thanks!
Thanks!
I have had 33x12.50s on mine. Just trimmed the front bumper. BUT I also had them on 15x10 wheels with 4 inches of backspacing.
Now I have 16x10s with 4 inches of backspacing and 305/70R16s witch is also basically a 33 1250. I'm looking at 315/75R16s right now. Might do cut out flairs or 2.5 inch lift to clear them.
From what I understand, it's more the width of the tire and backspacing that can cause problems than tire diameter. You could probably run 33x10.5 tires depending on the wheel without major issues. This depends on how your suspension sits too...some trucks sit higher up front than others just because of wear, or the springs that came with the truck. I'd imagine a 31x12.5 tire would be more likely to cause problems than a 33x10.5
I'm planning on getting a 32x10.5 for my stock suspension '88 4x4 f150 and don't expect any issues
With 31's on 91 F150 with 4.9 I am running under 2k rpms at 80. It does not make for a fun experience on the on ramp.
