2006 5.4l expedition engine serioously lacks power codes p0171 and p0175 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 11-14-2010, 10:06 PM
dreyko dreyko is offline
dreyko is starting off with a positive reputation.
p0171 and p0175
bank 1 too lean and bank 2 too rich
these codes dont make sence to me, this vehicle has a commonrail fuel system and a connected intake.
the engine lacks power so much so that it is undrivable. it hesitates and stumbles, it has yet to stall but acts like it wants to.
I have checked the maf and it is working properly.
I have removed both cats and saw no change.
I have tested vacuum and am seeing 15hg steady.
I have pressure tested the cooling system and am losing no coolant.
I have seen no smoke with the cats removed so I am doubtful of bad rings or head gaskets.
The engine idles steady, it almost feels like a terrible misfire but the lack of misfire codes leads me to think otherwise.
It will routinely act as if I am not applying throttle when I am.
I need to know how much vacuum this engine should generate at idle,
what numbers should a working tps read?
How dangerous is spark plug removal on this engine?
Any thoughts suggestions or ideas?
thank you,
Benjamin
Old 11-14-2010, 11:34 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Vacuum should be right around 20 Hg.
Did you test the fuel pressure, if so, what was the PSI?
Old 11-14-2010, 11:51 PM
FordMstrTech's Avatar
FordMstrTech FordMstrTech is offline
FordMstrTech is starting off with a positive reputation.
Beins this is a 3 valve engine, spark removal can be a pain, but i can give u some tricks that will help if u r interested. Is p0171 and 175 the only codes? I dont believe i have ever seen this problem. a rich and lean code set at the same time for the same bank. that is odd...i wouldnt think it would be fuel supply related beins its on 1 bank instead of both. But i could see fuel delivery to cause this issue. I have seen alot of trouble with injectors in this engine, but u normally have a missfire code such as p03xx depending on which cylinder is missing. I would recommend pulling the fuel rail up out of the intake. Leave the fuel lines connected to the rail and have some one turn the key on while u watch the injectors. There should not be any fuel to come out of the injectors with KOEO. If an injector does leak fuel replace it....
I have seen the electronic throttle bodies due some weird things as well, but they normally set dtc's as well/
I would also recommend watching the o2's and see what they r doing. R they running rich and then lean on bank1? What is really happening? U could have a PCM issue as well... Hope this helps
Old 11-15-2010, 12:49 AM
its not on the same bank its on 2 seperate banks.
p0171- bank 1 too lean
p0175- bank 2 too rich
I have not tested fuel pressure, I will tomorrow what numbers am i looking for?
I have heard that faulty tps's can cause odd sympoms on these vehicles, could that be a suspect?
And as for the spark plugs Im more referring to the likelyhood of stripping threads/ breaking plugs. Ive heard that the issue was addressed by the 2006 model year but I would like confirmation.
Thanks Guys
Old 11-15-2010, 09:47 AM
Quote:
Originally Posted by FordMstrTech View Post
that is odd...i wouldn't think it would be fuel supply related being its on 1 bank instead of both. But i could see fuel delivery to cause this issue.
I thought only politicians give two completely opposite answers to the same question.
Old 11-15-2010, 11:48 AM
soundtransmission soundtransmission is offline
soundtransmission is starting off with a positive reputation.
Quote:
Thanks Guys
Noooooooo ... unfortunately, 2007 was the year it was finally addressed.
Old 11-15-2010, 04:02 PM
Ok fuel pressure is around 50 primed and 45 at idle.
Did a fuel seperation test, no water in fuel.
still stumped....
Old 11-15-2010, 04:06 PM
How about the problematic PCV hose elbow at the rear of the intake? Have you inspected that for clogs, cracks, or breaks?
Old 11-15-2010, 07:12 PM
Thanks Guys
OOPS my bad. Brain fart. mk lean on bank 1 rich on bank 2 my bad. Thank you for correcting me...
Old 11-15-2010, 07:25 PM
Quote:
Fuel supply and fuel delivery are 2 separate systems, if thats what ur fussin bout.
Fuel supply= fuel pump, fuel filter, FPDM, Inertia switch
Fuel delivery= fuel injector, fuel injector o rings, fuel rail
If u were runnin rich on both banks instead of one then probably fuel supply system.
If u were runnin rich on one bank then probably fuel delivery system...
P0171 (Bank 1 Lean) and Random Misfires dclack 1997-2006 Expedition & Navigator 10 11-18-2014 03:19 PM
2001 F-150 4.6 liter Romeo Could these codes be caused by incorrect timing?? Dark Green F-150 1997 - 2003 F150 2 05-19-2014 01:02 PM
2001 Ford F-150 4.6 Romeo Timing Chain Replacement Dark Green F-150 1997 - 2003 F150 0 05-13-2014 04:44 PM
06 Ford Escape Sounds Like Diesel Nathandewalt Escape & Escape Hybrid 17 06-06-2012 09:20 AM
96 4.9 P0385, p1131, p1151, p0171, p0174 CharlesNChargee Electrical Systems/Wiring 0 04-15-2009 03:17 PM
Tags
2004, 2006, 46, 54, code, codes, engine, expedition, ford, generates, p0171, p0175, rich, running, vaccum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
