Piston Cooling Jets?
Old 11-14-2010, 06:11 PM
parr4's Avatar
parr4
parr4 is offline
New Ford engines have this system. Any description of what the system is/does?
Old 11-14-2010, 06:14 PM
FordMstrTech's Avatar
FordMstrTech
FordMstrTech is offline
Older ones had it too. I believe the 6.0 and may be the 7.3has it but i could b wrong.I know for a fact the 6.4 has it. It is a little spout that comes up at the bottom of the cylinder and spits oil under the piston to keep it cool.... Its really only needed on diesel engines due to the high temperatures in the cylinder.
Old 11-14-2010, 06:37 PM
parr4's Avatar
parr4
parr4 is offline
ok thanks. timed to individual piston travel?
Old 11-14-2010, 06:42 PM
Wyowanderer's Avatar
Wyowanderer
Wyowanderer is offline
No. It's just pointed at the underside of the piston crown, and shoots oil on it to keep it cool(er).
Old 11-14-2010, 08:54 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
The old idi 6.9 and 7.3 diesels had it also. The pistons can get very hot in a diesel engine, especially if they are overfueled. We try to tell people who love to turn their engines up and blow black smoke that they are getting ready to melt the pistons in the engine, but some don't listen and end up ruining it anyway.
Some of the big time diesel truck engines have a composite piston with a steel top and a aluminum bottom.
Old 12-11-2010, 07:14 PM
notyettoday's Avatar
notyettoday
notyettoday is offline
300 I6's had this system as well.
Old 12-11-2010, 07:27 PM
Franklin2's Avatar
Franklin2
There is no purpose for this feature in regular street driven gas engine.
Old 12-11-2010, 07:31 PM
notyettoday
the 300's had a problem with pistons disintegrating, probably because their low torque curve caused high cylinder temperatures due to high combustion pressure. regardless of whether or not it was necessary, ford added oil jets to the rods on the 300, however I believe it was necessary
Old 06-17-2011, 07:14 AM
'83f3fiddy's Avatar
'83f3fiddy
'83f3fiddy is offline
I can't see how that works, and doesn't kill oil pressure...I'd figure oil squirming in a open space all ill pressure would go away, since it takes path of less resistance...
Old 06-17-2011, 09:01 AM
AstroFab's Avatar
AstroFab
AstroFab is offline
How would it kill oil pressure? This has been done for many years on production engines as well as race engines and is a proven method for reducing piston temperatures. It's not just a hole where oil flows out of. The pressure is maintained by the sizing of the jets, or the groove sizes in the connecting rods.
YouTube - ‪Fastlane tears down the 2011 Ford 5.0L Mustang Motor‬‏
Old 06-17-2011, 09:27 AM
NavyMIDN08's Avatar
NavyMIDN08
NavyMIDN08 is offline
uses a small opening to ensure a steady jet of oil. the small opening is a restriction in-and-of-itself. it doesn't take much of a stream to keep the piston cool...
Old 06-17-2011, 10:27 AM
'83f3fiddy's Avatar
'83f3fiddy
I'd have to see one in person to figure It out..lol iv never torn a motor apart that has one..iv never heard of them until my friends miata, but I never saw a jet on the rods of the 1995 1.8 miata motor we tore apart..
Old 06-17-2011, 12:07 PM
AstroFab's Avatar
AstroFab
AstroFab is offline
Miatas have squirters that screw onto the block with a hollow Banjo Bolt.
Old 06-17-2011, 01:38 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Same concept as a garden soaker:
Old 06-17-2011, 02:49 PM
AstroFab's Avatar
AstroFab
AstroFab is offline
That's a good way to explain it...
Quick Reply: Piston Cooling Jets?
