Piston Cooling Jets? - Ford Truck Enthusiasts Forums
Old 11-14-2010, 06:11 PM
parr4 parr4 is offline
parr4 is starting off with a positive reputation.
New Ford engines have this system. Any description of what the system is/does?
Old 11-14-2010, 06:14 PM
FordMstrTech's Avatar
FordMstrTech FordMstrTech is offline
FordMstrTech is starting off with a positive reputation.
Older ones had it too. I believe the 6.0 and may be the 7.3has it but i could b wrong.I know for a fact the 6.4 has it. It is a little spout that comes up at the bottom of the cylinder and spits oil under the piston to keep it cool.... Its really only needed on diesel engines due to the high temperatures in the cylinder.
Old 11-14-2010, 06:37 PM
ok thanks. timed to individual piston travel?
Old 11-14-2010, 06:42 PM
Wyowanderer's Avatar
Wyowanderer Wyowanderer is offline
Wyowanderer is gaining momentum as a positive member of FTE.Wyowanderer is gaining momentum as a positive member of FTE.
Quote:
No. It's just pointed at the underside of the piston crown, and shoots oil on it to keep it cool(er).
Old 11-14-2010, 08:54 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The old idi 6.9 and 7.3 diesels had it also. The pistons can get very hot in a diesel engine, especially if they are overfueled. We try to tell people who love to turn their engines up and blow black smoke that they are getting ready to melt the pistons in the engine, but some don't listen and end up ruining it anyway.
Some of the big time diesel truck engines have a composite piston with a steel top and a aluminum bottom.
Old 12-11-2010, 07:14 PM
notyettoday notyettoday is offline
notyettoday is starting off with a positive reputation.
300 I6's had this system as well.
Old 12-11-2010, 07:27 PM
Franklin2's Avatar
Quote:
There is no purpose for this feature in regular street driven gas engine.
Old 12-11-2010, 07:31 PM
the 300's had a problem with pistons disintegrating, probably because their low torque curve caused high cylinder temperatures due to high combustion pressure. regardless of whether or not it was necessary, ford added oil jets to the rods on the 300, however I believe it was necessary
Old 06-17-2011, 07:14 AM
'83f3fiddy's Avatar
'83f3fiddy '83f3fiddy is offline
'83f3fiddy is starting off with a positive reputation.
I can't see how that works, and doesn't kill oil pressure...I'd figure oil squirming in a open space all ill pressure would go away, since it takes path of less resistance...
Old 06-17-2011, 09:01 AM
AstroFab's Avatar
AstroFab AstroFab is offline
AstroFab is starting off with a positive reputation.
How would it kill oil pressure? This has been done for many years on production engines as well as race engines and is a proven method for reducing piston temperatures. It's not just a hole where oil flows out of. The pressure is maintained by the sizing of the jets, or the groove sizes in the connecting rods.
YouTube - ‪Fastlane tears down the 2011 Ford 5.0L Mustang Motor‬‏
Old 06-17-2011, 09:27 AM
NavyMIDN08's Avatar
NavyMIDN08 NavyMIDN08 is offline
NavyMIDN08 is starting off with a positive reputation.
Quote:
uses a small opening to ensure a steady jet of oil. the small opening is a restriction in-and-of-itself. it doesn't take much of a stream to keep the piston cool...
Old 06-17-2011, 10:27 AM
'83f3fiddy's Avatar
I'd have to see one in person to figure It out..lol iv never torn a motor apart that has one..iv never heard of them until my friends miata, but I never saw a jet on the rods of the 1995 1.8 miata motor we tore apart..
Old 06-17-2011, 12:07 PM
AstroFab's Avatar
Miatas have squirters that screw onto the block with a hollow Banjo Bolt.
Old 06-17-2011, 01:38 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Same concept as a garden soaker:
Old 06-17-2011, 02:49 PM
AstroFab's Avatar
Quote:
That's a good way to explain it...
Entire clutch system must be replaced if air has entered system? DSparksF250 1987 - 1996 F150 & Larger F-Series Trucks 3 10-30-2016 10:47 PM
Ac system Ugandaprof 2004 - 2008 F150 0 07-01-2013 01:41 PM
PATS lakedweller 6.7L Power Stroke Diesel 13 04-29-2011 02:57 PM
Welded or Bolt On Exhaust? byoungquist Exhaust Systems 3 11-29-2010 01:22 PM
Exhaust fastball 2009 - 2014 F150 16 03-31-2009 04:54 PM
Tags
block, cooling, engines, f150, ford, fords, injection, jets, motors, pistion, piston, pistons, small, system, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
