Piston Cooling Jets? - Page 2 - Ford Truck Enthusiasts Forums
Old 06-17-2011, 02:56 PM
Old Hickory's Avatar
Old Hickory Old Hickory is offline
Old Hickory is gaining momentum as a positive member of FTE.Old Hickory is gaining momentum as a positive member of FTE.
Some of the very early small block Ford engines had squirt holes in the rods. I saw themback in the 1960s at my buddys garage when they were rebuilding either a 221 or
260 CI engine.
Old 06-17-2011, 03:30 PM
AstroFab's Avatar
AstroFab AstroFab is offline
AstroFab is starting off with a positive reputation.
Yeah the 221, 260, and early 289's had oil holes in the connecting rods.
Old 10-07-2013, 08:58 PM
jonathanpatr jonathanpatr is offline
jonathanpatr is starting off with a positive reputation.
Piston cooling jets on the 6.9 liter engine
6.9 diesel manual says piston cooling jets must be replaced by a reputable, professional mechanic. all of a sudden I feel less than qualified. I can't find tools or the parts, anyone out here have some insight on why they neeed to be replaced, if they need to be replaced, how to aim them after honing,
thanks
Jonathan
Old 10-07-2013, 09:31 PM
Blue_Oval1 Blue_Oval1 is offline
Blue_Oval1 is starting off with a positive reputation.
Quote:
Originally Posted by parr4 View Post
New Ford engines have this system. Any description of what the system is/does?
The system is present at least on the new 5.0 Coyote V8. According to 5.0 Mustang Magazine after talking with Ford engineers, the squirters were installed such that the pistons run cooler. This allows for using cheaper hypereutectic pistons in the 7000 rpm redline Mustang version of the engine rather than requiring more expensive forged units. It also helps with the engine's ability to run 87 octane fuel in the 11.0:1 engine without requiring direct injection. Fewer hot spots = less detonation = can run less octane.
Source: 2011 Ford Mustang GT 5.0 Coyote Engine - 5.0 Mustang & Fast Fords
Old 10-07-2013, 10:48 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
Originally Posted by Blue_Oval1 View Post
Reps to you for citing sources!
Entire clutch system must be replaced if air has entered system? DSparksF250 1987 - 1996 F150 & Larger F-Series Trucks 3 10-30-2016 10:47 PM
Ac system Ugandaprof 2004 - 2008 F150 0 07-01-2013 01:41 PM
PATS lakedweller 6.7L Power Stroke Diesel 13 04-29-2011 02:57 PM
Welded or Bolt On Exhaust? byoungquist Exhaust Systems 3 11-29-2010 01:22 PM
Exhaust fastball 2009 - 2014 F150 16 03-31-2009 04:54 PM
Tags
block, cooling, engines, f150, ford, fords, injection, jets, motors, pistion, piston, pistons, small, system, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
