random extended crank times
2002 mm 4.0 random extended crank times what would you recommend checking? like i say its totally random usually starts by holding the key in start position for 1-2 seconds but like i said random extended crank times of upto about 5-10 seconds and then it will start normal after that for a while can be warm or cold engine when this happens.
thanks wayne
thanks wayne
I am having the same problem with my 94 Explorer. This problem has caused me to replace original parts - fuel pump assembly, fuel filter, fuel pressure regulator - with new Motorcraft parts. These replacements were caused by diagnosis of poor fuel pressure, not lack of fuel pressure. I have also run a can of Seafoam in the gas through the engine. I have cleaned connections to the ICM and the coil pack. The problem is random, sometimes I have to turn the key on and off up to 7 or 8 times to get ignition. The fuel pump runs its normal 2-3 seconds, all the appropriate dash lights are on and the fasten seat belt chime works so I am not experiencing a total PCM failure. This weekend my Explorer is sitting around with a fuel pressure gauge attached which I borrowed from my mechanic. I am starting it 2 or 3 three times per day. One failed start happened Saturday morning before I put the gauge on. I turned the key twice with no fire. I put the gauge on and turned the key, got good pressure and no fire, turned the key on again and the engine fired and started. I am trying to trap the condition to prove either a no fuel pressure or a no spark condition. I will post again if I can find anything conclusive.
An update to my no start problem. For the past six days my Explorer has sat in my garage with a fuel pressure gauge attached. I have started the car 3 to 4 times a day without encountering any problems. The fuel pressure reads 36psi after fuel pump prime and 28psi when engine is running. The first day prior to installing the pressure gauge I had a no start situation on the first start attempt. I installed the pressure gauge and tried again - second time no start - fuel pressure read 36psi. On third start attempt the engine fired and continued to cooperate for the rest of the week. I am now looking for an intermittent electrical ignition problem, I am satisfied fuel pressure is not the problem. I have been advised to watch the tach when the no start condition occurs, if the tack is not moving then zero in on the primary ignition system.
schweetheart
09-01-2016 08:57 PM
Peter M
1999 to 2016 Super Duty
13
10-26-2012 01:14 PM
