Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Transit Connect
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Transit Connect 2010 Ford Transit Connect
  #1 (permalink)
Old 11-14-2010, 04:34 PM
bigbug56 bigbug56 is offline
Garage is empty, add now
bigbug56 is starting off with a positive reputation.
1995 Ford fuel problems
My 1995 Ford F 150 truck idles fine but when you accelerate , or push the gas pedal down past halfway it starts cutting out. If you keep the pedal below half way down it runs great. I talked to a mechanic on line and he said it was the maf sensor. But I don't thing it has a sensor. I think it has air flow bypass valve, or thats all I see attached to the throttle body. I have installed a new fuel filter, but it didn't help. Does any one know what might be causing the problem. The engine is a 5.8 litre. It also has a double air intake attached to the throttle body?
  #2 (permalink)
Old 11-15-2010, 01:01 PM
w6pea's Avatar
w6pea w6pea is offline
w6pea is starting off with a positive reputation.
Question
I am not an expert...I had a similar problem, if you have access to a code reader have the codes read. Could be an EGR Problem. I'm not sure. This may sound lame when was the last time you changed the air filter....IMO if you are running a K&N Filter get rid of it.
Just a thought. Hope that helps.
__________________
"Without Trucks and Truck-Drivers America Stops" "OOIDA Lifetime Memeber"
Why Do I have to Press "1" to speak English in America ?
95 F-250 Super Cab XLT "460" 7.5L V-8 Gas,E4OD Trans. 8ft.Bed
04 E-450 Super Duty V-10 6.8L
"Once a Marine Always a Marine" "Semper Fi"
Tags
1995, 58litre, 73, cutting, diesel, e450, ford, fuel, international, issues, maf, sensor, troubleshooting, truck, trucks, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
