Jason,
Easy to install. About 3 hrs but I loafed. They said 2 man job but I did it by myself. What do you need for pictures?
Dieselstop did an install on ther project truck. 4
wheel and off road did one also.
I like the fact the winch sits in line with the frame and is so close to the frame.
As far as install if I remember right.
Remove
bumper
Remove tow hooks
Bolt in mount side rails to where tow hooks were(3 bolts).
Attach bottom of winch cradle to side rails.
Bolt in winch to cradle.
Install upper cradle arms to frame of truck.
Swing cradle up and bolt to cradle arms.
Remove
bumper brackets from bumper.
Put in new
bumper attachments.
Drill ends of
bumper for black plastic extensions.
Bolt in extensions to ends of bumper.
Set skirt on winch mount.
Bolt
bumper up to winch mount.
Install fairlead and hook.
Connect power to battery.
Find something to hook on to.
Spool it out till 4 wraps remain.
Spool it in using the truck to keep the cable tight.
Did I miss anything?
Oh yea smile as you recover some Z71 stuck in the sand.
