I bought a 52 F-1 that has a Nova clip installed, the VIN plate on the glovebox door was not riveted/screwed onto the door but sitting inside the glovebox, the title VIN # reads exactly what the VIN plate reads except for the plate has 3 extra letters in front of the #'s, the rest of the #'s are the same, is that normal?
What held the VIN plate to the glove box door? A picture would be great.
Thanks!
The tag reads F1R2RH-17506, the Registration reads R2RH17506, guess the F1 is obvious.
I would like to stamp the frame with the correct VIN as the Nova frame has nothing, would they have used the F1R2RH-17506 or the R2RH17506 from the factory? Thanks.
The asterisks are really hollow 5 point stars. I didn't go out to see if they're on my 52 but they are there on the two 48's and the 50. Just cleaned the '50 frame the other day for registration purposes so I can get the bonded title.
Interesting. I wonder if that's a 48-50 VS 51/52 thing, or if it was different from plant to plant. Mine (51) definately doesn't have them on the frame.
(Of course oddly, mine was US built [Long Beach] and the serial number was stamped on the drivers side - like a Canadian truck!)
I know that I've seen the stars on the 48-50 frame that I just sold. I still have the front portion of the 52 frame that you (Julie) and I split. I should try to find the vin there and see if it has the stars.
I have a feeling that it's a 48-50 vs 51-52 thing.
