52 F-1 VIN ? - Ford Truck Enthusiasts Forums
52 F-1 VIN ?
Old 11-14-2010, 01:10 PM
orcas tow's Avatar
orcas tow orcas tow is offline
orcas tow is starting off with a positive reputation.
52 F-1 VIN ?
I bought a 52 F-1 that has a Nova clip installed, the VIN plate on the glovebox door was not riveted/screwed onto the door but sitting inside the glovebox, the title VIN # reads exactly what the VIN plate reads except for the plate has 3 extra letters in front of the #'s, the rest of the #'s are the same, is that normal?
What held the VIN plate to the glove box door? A picture would be great.
Thanks!
Old 11-14-2010, 11:33 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Post a picture if you can. The Data tag (VIN) was held in with screws.
The VIN should be something like this:
F1R2RH123456
F1 - 1/2 ton
R - 239 V8
2 - 1952
RH - Richmond, CA plant
123456 - production sequence number
Also, in 1952 Ford eliminated another data tag that was affixed in the upper right-hand corner of the firewall in 1948-1951 Ford trucks.
Old 11-14-2010, 11:53 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
I can't guess whether it's normal or not without knowing what the numbers/letters are.
Ford varied things a LOT back then.
Old 11-15-2010, 12:08 AM
orcas tow's Avatar
The tag reads F1R2RH-17506, the Registration reads R2RH17506, guess the F1 is obvious.
I would like to stamp the frame with the correct VIN as the Nova frame has nothing, would they have used the F1R2RH-17506 or the R2RH17506 from the factory? Thanks.
Old 11-15-2010, 12:22 AM
51PanelMan's Avatar
I edited my original post. RH is Richmond, CA plant. I had RH in the VIN example and RC in the decode example.
So, the correct sequence is F1R2RH17506 and would have been stamped in the frame raile with one star before and after the sequence.
Old 11-15-2010, 02:06 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
The asterisks were not stamped in the frame as they were embossed on the rating plates.
Ilya is correct - the full number with no gaps or hyphens.
Old 11-15-2010, 10:32 AM
51PanelMan's Avatar
Julie may be right on the asterisks. However, I remember seeing them on at least one frame.
Doesn't really matter how you stamp it since the front end of the frame isn't stock.
Old 11-15-2010, 07:13 PM
The asterisks are really hollow 5 point stars. I didn't go out to see if they're on my 52 but they are there on the two 48's and the 50. Just cleaned the '50 frame the other day for registration purposes so I can get the bonded title.
Old 11-15-2010, 07:32 PM
Quote:
Interesting. I wonder if that's a 48-50 VS 51/52 thing, or if it was different from plant to plant. Mine (51) definately doesn't have them on the frame.
(Of course oddly, mine was US built [Long Beach] and the serial number was stamped on the drivers side - like a Canadian truck!)
Old 11-15-2010, 09:38 PM
51PanelMan's Avatar
I know that I've seen the stars on the 48-50 frame that I just sold. I still have the front portion of the 52 frame that you (Julie) and I split. I should try to find the vin there and see if it has the stars.
I have a feeling that it's a 48-50 vs 51-52 thing.
Old 11-17-2010, 10:55 AM
51PanelMan's Avatar
Yesterday I looked at the spare fream section that I have. It's a 1952 frame and does have the stars in front and rear of the stamped VIN.
Old 11-17-2010, 11:40 AM
al.lug's Avatar
al.lug al.lug is offline
Al Lugtenburg
al.lug is starting off with a positive reputation.
Hi, If that helps, I have both asterisks before and after my 51 F1 VIN number. It looks like that: *F1R1EG392439*.
Old 11-17-2010, 11:51 AM
51PanelMan's Avatar
Hi Alex,
Nice to see you on here.
"EG"?? I wonder what production plant that is. Do you know where your truck was originally made or where it came from?
Thanks, Ilya
Old 11-17-2010, 12:12 PM
al.lug's Avatar
Al Lugtenburg
It's from Edgewater, NJ.
Old 11-17-2010, 12:14 PM
merlynr's Avatar
merlynr merlynr is offline
merlynr is gaining momentum as a positive member of FTE.
EG = Edgewater, New Jersey according to my paperback "redbook".
VIN question willowbilly3 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 02-16-2015 08:22 AM
Canadian M3 VIN help? BaggedMerc 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 01-05-2015 12:30 AM
Numbers stamed in cowl SunnyBeach 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 05-20-2014 01:01 PM
where to find 1959 f100 glovebox vin plate rivets? sasquatchmystery 1957 - 1960 F100 & Larger F-Series Trucks 1 04-02-2014 12:21 PM
Canadian 1952 f-1 52 ford pick-up 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 10-15-2012 07:55 PM
Tags
1951, 52, code, die, f1, ford, ist, location, number, parts, pick, production, read, sequence, truck, vin, wo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
