92 F350 7.5L, 5-Speed HEADERS???? - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 09-17-2011, 09:27 PM
ceetwarrior's Avatar
ceetwarrior ceetwarrior is offline
ceetwarrior is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 1987F250460 View Post
ok thank you very much . Will I be able to get better gas milage?
Maybe at lower RPM's you'd get better mileage... but if you're upping the main jets your using more fuel when your foots in it..... so no you wont get better overall mileage.
  #47
Old 09-18-2011, 11:08 AM
1987F250460 1987F250460 is offline
1987F250460 is starting off with a positive reputation.
Quote:
So you said it is not much of a difference just going with open exhaust, so that means I won't need to add extra fuel. Is there any way to tell if I might be lean? I have an old 87 truck nothing to tell by unless I dyno it lol.
  #48
Old 09-18-2011, 11:16 AM
Just research on tuning carbs. Usually just check the color of your spark plugs and go from there...
  #49
Old 09-18-2011, 12:34 PM
Nice you are a True Guru
  #50
Old 10-27-2011, 06:53 AM
jarod17's Avatar
jarod17 jarod17 is offline
jarod17 has a very good reputation on FTE.jarod17 has a very good reputation on FTE.jarod17 has a very good reputation on FTE.jarod17 has a very good reputation on FTE.
Yep, I had to mod my y-pipe to crossmemeber. Basically took the cross bracket off, slid it back and cut off an edge. Works great
Did you cut off an edge of the y-pipe or the bracket? I have had this set in my '96 for two years now and just swapped the auto out for the 5-speed. This has me on hold and on foot at the moment. Do you have any photos of the y-pipe installed? This will help out a lot. Thanks
  #51
Old 10-27-2011, 10:43 PM
Quote:
I just cut off an edge on the front of the crossmember for extra clearance. Its way to cold to go take a pic now, even in my garage LOL.
  #52
Old 10-27-2011, 10:51 PM
jarod17's Avatar
That's cool, I understand about the weather. Getting too cold to do much up here. I can visualize what you are talking about now. I am just going to temp mine with flex pipe for now and build a new y-pipe later. Thank you.
  #53
Old 08-13-2012, 10:35 AM
IcutMetl's Avatar
IcutMetl IcutMetl is offline
IcutMetl is starting off with a positive reputation.
Reviving an old thread here; how are your headers holding up and what exhaust did you put behind them? I have a similar situation in a 97 and am looking at options other than Banks that include a Y-pipe. Can you fit the headers in w/o moving the engine?
  #54
Old 08-14-2012, 05:31 PM
Quote:
Headers are doin fine. They DO come with a Y pipe that bolts up to factory stuff. I put a big body 3" magnaflow on it (no cat), I love the sound with the side pipes. Its been a while but I believe I had to lift up motor a lil bit to get 'em in...
  #55
Old 11-17-2012, 04:58 PM
BearFootCustom's Avatar
BearFootCustom BearFootCustom is offline
BearFootCustom is starting off with a positive reputation.
I put them on my 93 and didnt have to jack the engine up. Just have to slide it up from under the truck. Im workin on the y pipe now
  #56
Old 12-15-2012, 01:18 PM
la67flat4 la67flat4 is offline
la67flat4 is starting off with a positive reputation.
Had a set myself. I Chucked them about 5 years ago and got some L&L headers. They are night and day different in quality.
  #57
Old 12-15-2012, 06:16 PM
Quote:
Yup and big cost difference too, huh.
  #58
Old 02-15-2013, 05:55 PM
You have any pics of how you modded the bracket to y pipe? I have mine close but not satisfied with the clearances
  #59
Old 02-16-2013, 10:25 AM
I basically just cut out a corner of it to make it work. I ended up with about 1/2" of clearance.
  #60
Old 05-25-2013, 05:30 PM
Finally bought a new egr valve. Where did you get the egr tube and fittings? I cant find any fittings that are the same thread as the bung on the headers
5.8 Headers FREDDAY Ford Truck Parts for Sale 0 03-25-2016 08:55 AM
gain hp + improve MPG evil-90 Performance & General Engine Building 17 09-03-2015 08:26 PM
Need help finding headers 7.5L Usaallday Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 12-04-2014 10:45 AM
1990 7.5L 5-sp Headers, Air Pump Delete F350 1990 1987 - 1996 F150 & Larger F-Series Trucks 4 02-05-2014 09:47 PM
Headers for 1990 E350 7.5L E4OD? BII Plow Truck Exhaust Systems 2 02-27-2013 04:59 PM
Tags
460, 75, 75l, 92, banks, computer, delete, engine, ford, header, headers, kit, liter, pump, sale, smog, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
