sexy brake booster question.
Its a No Limit wide ride front end I notched the cross member a little for pan clearence you can check out more of the build search: my 58 f100 project
Thanks Jeff
As an option, check out Engineered Components. They have a firewall mount brake pedal with an offset to set the brake booster away from the valve cover: Firewall Mounted Brake and Clutch Master Cylinder Mounting Systems
scott79
16
05-18-2015 04:28 PM
jdbanks
12-03-2006 11:01 AM
