Dash smoothing...amateur style!
So, when I bought my truck, there were two holes in the dash from who knows what. I'm guessing one of the previous owners had some gauges in there. Also, there was an open hole where the throttle **** was, and the choke **** was there, but not hooked up to the carb. So, enter some bondo and my serious lack of skills+some frosty beverages. Here's the carnage...
Step one, sand down the area to be bondo'd. Check.
Step two, locate some backing material. Double check.
Step three, install said backing material. Man, I'm a professional!
Step four, slab on some bondo....maybe I'm not the professional I originally thought...
Step five, while waiting for the bondo to dry, enjoy a frosty beverage. I'm pretty good at this step.
Step six, get some high quality, triple density, double tough, insanely expensive over coat.
I got a few coats of paint on, but it got too dark to take any decent pictures.
So, the final astounding product will be on display for all you good people...tomorrow.
Nothing new in case you think so. Old school custom work, like 1955 or older.Common practice in bondo body shops even today. Best to learn it the correct way. But you do it your way ,most people won't know the difference accept a few of us.
.................................................. .................................................. .................................Edit.........the choice of brew may be different than the 50s,thats all.
Nothing to lose, tho. The alternative requires a grand or more in TIG machine, a lot of skill, and might take a week to get done "right", after which you'd still end up slathering a coat of bondo over it. Time will tell...
I would hope it would be final , but my experiance has been shortly after I get the painting done and eveything back in place, two little circles will appear. Been there and done that more than once. I know he said "amateur" and I understand, but if it's worth doing, do it right. Good luck to him and his project .
I did sand it down. And as of right now, I have nothing but time. If it cracks, then I learn and make it right. If it doesn't, not a bad way to spend 20 bucks and a few hours. Either way, it is still an improvement over having two large holes in the dash. The most effective way to learn how not to do something is to screw it up.
Patches can be welded in with a arc welder,takes practice. Or the way I did before I got a arc welder and later a wire feed welder. Torch and soft rod or real old amateur way ' wire coat hangers ,hay bailing wire, L.O.L. Then lead work , which I never did get very good with, a lot ended up on the floor.
Step 2. Taking stock of your environment (i.e. does the frosty beverage dispenser contain an adequate amount of frosty beverages)
Step 3. take a fearless moral inventory of your thirst and compare with stock of frosty beverages on hand
Step 4. Procure the adequate amount of frosty beverages for your thirst and that of your friends who might stop by
Step 5. Enjoy said frosty beverages (repeat as necessary)
