Hi all! Have a 68 truck and a 58 panel. FTE has been a lot of help. Hope you all can help us with this problem. My son just got a 1988 truck 460 motor has dual tanks. Only one tank works, last owner had miss with everything so something's are missing. Is there a layout of the electical and the plumbing that show's everything from the tanks to the motor?
Thank you for sending that!! But looking for double tank lay out because somethings is missing as well as wireing spliced and taped.My son did not realized the mess that was done under there untill crawling under the truck to see what last owner had done.
