Got the ol' dual tank switch valve issue. - Ford Truck Enthusiasts Forums
Old 11-13-2010, 08:16 PM
Markgyver Markgyver is offline
Markgyver is starting off with a positive reputation.
Problem is, my truck is a Jan of 1989 model with the frame rail switch valve AND high pressure pump. The rear tank supplies the engine, but bleeds into the front tank and out the fill nozzle if not stopped. Intermittantly the front tank pump fails forcing use of the rear tank pump. The strange part is with the front tank completely full I can toggle to the front tank but the fuel level will not go down. Toggling to the rear tank the fuel level has decreased. Having been told the problem is the switching valve with the part number being, FLUZ9B263B. Cannot be found through Ford or any aftermarket parts supplier. Any help here?
Old 11-13-2010, 08:34 PM
imabaka's Avatar
imabaka imabaka is offline
imabaka is starting off with a positive reputation.
Odd a year ago I walked into my ford dealer and told them what I needed and the guy new exeactly what it was and ordered me one for 100 bucks
Old 11-13-2010, 08:55 PM
re: dealerships.
The dealership is where I got the recall number, the original and replacement "fix kits". Unfortunately, the recall (according to Ford) only goes back to 1990 models. Mine being early 1989 does not "qualify", and they could not sell me the kit. Have yet to find the kit, OEM valve, or proper aftermarket part/s.
I do appreciate the reply though.
Old 11-17-2010, 06:22 PM
knibbeone knibbeone is offline
knibbeone is starting off with a positive reputation.
6 port? I JUST bought one yesterday< if ya need to part number, lemme know
Old 11-17-2010, 10:25 PM
About the 6 port.
Hey thanks for the reply.
I actually have the number from a website refered by Ford Motor Co. I just can't justify over $200 for the valve. I find the part on a wholesale outlet online, but the part doesn't look the same. Tried to cross-reference it... no dice. Was told that my truck did not have two tank pumps AND a frame-rail pump... but it DOES! What is weird is that if I start on rear tank it will overflow the fillspout. But if I switch to the front tank it runs without overflowing the fill spout. If the switch is bad, wouldn't it still overfill the front tank? The guys @ dealership parts counter are baffled. My truck is too old for the Ford recall by one year, though share the SAME parts. GRRR! Even trying to plumb directly from rear tank to pump is major issue. I've concidered a salvage part, but I know how that goes.
I grew up a Chevy fan, got this truck. Became impressed (don't tell dear ol' dad, grave will rumble). Kinda grew fond of this ol truck. But money is money! LOL
Would love to find the answer.
Old 11-18-2010, 12:01 AM
it sounds like the valve, everything i read tells me that on yours. I did purchase my valve from ford for 160 including tax. It fixed that issue but not the running problem. I talked to ford and most of the guys disconnected the front tank, ran off the rear and no more overfill issues. Then you by pass the selector valve altogether. The high pressure does not start until the frame pump. the tank pump is less than 10 psi so you can use a hose and clamps over the top. Just make sure the return goes back to the rear tank. Good Luck?
Old 11-18-2010, 09:38 AM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
We carry the 3 and 6 port valves here. Here's a link to them if anyone would like to check prices.All of our parts have free shipping and no handling fees.
Ford F150 Fuel Tank Selector Valve
Old 11-18-2010, 09:51 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Go to another Ford dealer as they do not know about your fuel system at that Ford dealer.
The 1990 and newer recall is for a different fuel system.
The Valve can only be bought from a Ford dealer, the after market 6 port valve at the auto part stores is the wrong one and does not have a reservoir and needs electrical wires. Yours does not use any wires and is switched by pressure.
Bypassing it will not work either as the high pressure pump needs the reservoir in the bottom of the valve for WOT and going up hills.
The link above is for the wrong valve.
The right one:
Old 11-18-2010, 10:28 AM
Turx Turx is offline
Turx is starting off with a positive reputation.
Wow! subford great info. My 97 F259HD 4x4 just started having a gauge issue this week. Rear tank and gauge work fine and supply fuel with no issues, front tank works, supplies fuel, but the gauge doesn't work. Just a ground prob?
Old 11-18-2010, 10:37 AM
1ATony's Avatar
PREMIUM SPONSOR
The one that I had posted is universal that's why. I showed one of our purchasing guys the one you posted. I'll see if it's something we can get and stock for you guys.
Thanks for posting.
Tony
Old 11-18-2010, 10:44 AM
subford's Avatar
Quote:
When a gauge does not work it has either lost conanuty (open circuit pegged gauge) or the float has sunk (low resistance to ground).
Old 11-18-2010, 05:36 PM
Aww now yer tawkin!
The right one:
Now that looks like the animal! Besides salvage gambling where might a feller get one?
PS. Thanks to all.
Old 11-18-2010, 06:04 PM
subford's Avatar
Any ford dealer should be able to order it.
Just have them order this part number:
F1UZ-9B263-B
Also you may want to look at this link:
Ford E
Old 02-10-2011, 11:36 AM
87 Ford Driver 87 Ford Driver is offline
87 Ford Driver is starting off with a positive reputation.
Hope I'm not too late!
I just recently got a 87 F150 that I'm having issues with. It seems as thought no fuel is reaching the engine. The guy I got the truck from said the rear tank would fill and overflow the front tank so that led to the FSV. I hunted and hunted until I found the OEM part for my truck. I saw that others were looking for the same part so I decided to post it. It is sort of pricey, but I think it is worth having. Here's the link below. Good luck!
F1UZ9B263B RESERVOIR ASSEMBLY-FUEL SELECTOR OEM FORD: F1UZ9B263B-Delray Auto Parts Direct To You | AutoPartsDirectToYou.com
Old 02-10-2011, 11:52 AM
Gregallen's Avatar
Gregallen Gregallen is offline
Gregallen is starting off with a positive reputation.
Ok this isnt far off topic and I habe no info sorry.
90 150 the back tank guage works fine but the front the gauge only goes to 1/4 tank as emptey and full.is past the mark is it just the way they are or could my float be messed up
Dual tank fuel selector valve khaitan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 28 12-03-2016 08:38 PM
1989 f250 fuel issue Blueriver16 1999 to 2016 Super Duty 1 09-07-2016 07:31 AM
'94 460 dual tank gas-fuel moving from rear tank to front? Ex-ChevyOwner Fuel Injection, Carburetion & Fuel System 2 10-07-2015 09:14 PM
89 F150 4x4 Dual Fuel Tank Switch predaina 1987 - 1996 F150 & Larger F-Series Trucks 29 03-29-2011 07:07 PM
92 F-150, duel tank fuel system Firefighter0513 1987 - 1996 F150 & Larger F-Series Trucks 6 02-05-2011 02:06 PM
Tags
1978, 1996, chevy, diesel, dual, econoline, electric, ford, picture, recall, replacement, selector, switch, tank, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
