Will a 7.3 oil dipstick tube work on a 6.9
Old 11-13-2010, 07:31 PM
andrew1's Avatar
andrew1
andrew1 is offline
Got everything back together and realized I didn't but the dipstick on and lost the block adapter for the dipstick! Does anybody have a pic of the passenger side? What do i have to do to get to the dipstick out because it look's like I have to remove the manifold again.
FYI! I changed the passenger side exhaust manifold with a 7.3 exhaust manifold. Now I need to go back and get the oil tube dipstick are they interchangeable?????
Old 11-13-2010, 07:54 PM
oreocreaming's Avatar
oreocreaming
oreocreaming is offline
you dont have to remove anything. it slips between the manifold and the gasket, clamps onto the valve cover bracket. theres an O ring that goes around the tube. yes, 6.9 and 7.3 are the same. you can get another block adapter for it from ford. not sure if anywhere else might have one. if i find my extra one i can send it out to you.
Old 11-13-2010, 07:59 PM
andrew1's Avatar
andrew1
andrew1 is offline
buddy has one at his shop, just getting it is the problem.
I looked and it want fit between the exhaust, dont even see the spot where it goes in the block!
Old 11-13-2010, 08:55 PM
oreocreaming
goes between #3 and #5 cylinders.
Old 11-13-2010, 08:58 PM
andrew1's Avatar
andrew1
andrew1 is offline
It want fit throught it, ill check it out in the morning.
Old 11-13-2010, 09:05 PM
oreocreaming
ya, its gotta fit if thats where it goes. ive taken mine out a couple times with no problem.
Old 11-13-2010, 09:06 PM
andrew1's Avatar
andrew1
andrew1 is offline
is there an alternative to the block adapter?
Old 11-13-2010, 09:18 PM
oreocreaming
if there is, i havent seen it. im sure someone will chime in soon enough.
BuickBrian
WTB - Parts & other
02-07-2018 08:08 AM
Tsprague706
05-10-2017 08:09 PM
jaymcjay
09-11-2016 04:35 PM
PSU4ME
07-25-2016 06:25 AM
33homerdoodle
11-01-2012 04:15 PM
Quick Reply: Will a 7.3 oil dipstick tube work on a 6.9
