Will a 7.3 oil dipstick tube work on a 6.9 - Ford Truck Enthusiasts Forums
Old 11-13-2010, 07:31 PM
andrew1's Avatar
andrew1 andrew1 is offline
andrew1 is starting off with a positive reputation.
Got everything back together and realized I didn't but the dipstick on and lost the block adapter for the dipstick! Does anybody have a pic of the passenger side? What do i have to do to get to the dipstick out because it look's like I have to remove the manifold again.
FYI! I changed the passenger side exhaust manifold with a 7.3 exhaust manifold. Now I need to go back and get the oil tube dipstick are they interchangeable?????
Old 11-13-2010, 07:54 PM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
you dont have to remove anything. it slips between the manifold and the gasket, clamps onto the valve cover bracket. theres an O ring that goes around the tube. yes, 6.9 and 7.3 are the same. you can get another block adapter for it from ford. not sure if anywhere else might have one. if i find my extra one i can send it out to you.
Old 11-13-2010, 07:59 PM
andrew1's Avatar
buddy has one at his shop, just getting it is the problem.
I looked and it want fit between the exhaust, dont even see the spot where it goes in the block!
Old 11-13-2010, 08:55 PM
goes between #3 and #5 cylinders.
Old 11-13-2010, 08:58 PM
andrew1's Avatar
It want fit throught it, ill check it out in the morning.
Old 11-13-2010, 09:05 PM
ya, its gotta fit if thats where it goes. ive taken mine out a couple times with no problem.
Old 11-13-2010, 09:06 PM
andrew1's Avatar
is there an alternative to the block adapter?
Old 11-13-2010, 09:18 PM
if there is, i havent seen it. im sure someone will chime in soon enough.
Drivetrain out, what should I PM? jaymcjay 1999 - 2003 7.3L Power Stroke Diesel 4 09-11-2016 04:35 PM
Dipstick and tube for 1990 7.5/460 BuickBrian WTB - Parts & other 1 08-24-2016 02:14 PM
Part numbers. Dipstick tube?? PSU4ME 1994.5 - 1997 7.3L Power Stroke Diesel 10 07-25-2016 06:25 AM
Stock 360 dipstick tube CJK09 1967 - 1972 F-100 & Larger F-Series Trucks 1 07-05-2015 01:00 PM
Dipstick tube bren7176 WTB - Parts & other 1 12-18-2011 05:31 AM
Tags
1990, 68l, 69, 69l, 73, boss, diesel, dip, dipstick, flathead, ford, oil, stick, tube, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
