im not sure on how the gear vender works. iknow this dual range is supposed to be simple to workon so i hear. they say anyone who works on standard transmissions can work on it.
Same with the GV, However I want the US Gear unit as well, the GV unit attaches to the back of the transfer case on a 4x4, thus cannot be used in 4wd, if the lockout fails it could get expensive real quick, though I have never heard of it happening and most that have the GV like it.
anybody know of any problems with the dual range? i picked it up for 50 bucks as a complete deal at the wrecking yard. so i think i did pretty good with that then there is the 100 bucks to have the drive line shortened. but it seems to work and drive real nice.
Still see no reason for wanting overdrive in 4x4.
If road conditions warrant 4x4, I probably won't even be running in high gear on the four speed.
If you run on mountain passes in the wintertime, having the extra gears to split would be beneficial. If 3rd is too low and 4th is too high when loafing along...
Plus, what fun is it if you can't run 80 mph on packed snow? All the SUV's that pass me that I see upside down in the ditch, 20 miles down the road, seem to think so
Exactly, it's for the split, not the high gears ...
i had a us gear on my 84 auto when i bought it... never had trouble was fun to us to blow smoke (when i had bad injectors), while ago it woudl stop spinning even when the motor was off. so i unpluged it, later when my injectors finaly quite i found burnt wires. im going ot fix the wires re plug in and i have new injectors and my overdrive back not to mention my turbo
