how to remove front headlight assembly?
Old 11-13-2010, 02:32 PM
Gramps86's Avatar
Gramps86
Gramps86 is offline
need to replace the drivers side lense assembly as a tree branch decided a while ago that it wanted the corner lense more than i do, also the bulb is out on the opposite side. cant figure out how to get the light assemblys out though..... there are 2 screws in the top, but cant find any other ones? any thoughts? thanks.
Old 11-13-2010, 02:40 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
Old 11-13-2010, 02:54 PM
Gramps86's Avatar
Gramps86
Gramps86 is offline
thanks.....thats pretty gay how you have to take it apart.....leave it to ford haha. thanks again will get to that next week.
Old 11-13-2010, 02:58 PM
CWPottenger's Avatar
CWPottenger
CWPottenger is offline
I literally just did this this morning...
Not sure what year yours is.
On mine a 90 F150 a bit of a process!!!
I will give a write up on a 90 model might help...
The headlight comes out with 3 4mm bolts... all on top. two facing the front on the corners of the lens .. thread out normal.. 3rd actually undoes bottom.. it is also on top just behind headlamp... actual clockwise to unbolt.
once lamp assembly out unplug lamp and set aside.
next remove center grille.
also need to remove plastic rivet screws in plastic cowl cover above headlamp.
there are 3 nuts( 7/16 or 10mm) to come off black plastic housing to the inner side.
on the back side towards fender there are 2 8mm bolts and 2 7/16 or 10mm bolts to remove.
after that the corner lamp and entire plastic headlamp mounting assembly will come out.
back side 3 more screws to separate corner lamp from housing.
reassembly just reverse....
REAL PITA for a corner lens...
kmjone00
Ford Truck Parts for Sale
08-21-2017 09:57 PM
kkelly54
12-10-2016 01:59 AM
Nick_Good
08-03-2010 12:51 PM
Ultraboy
02-01-2010 09:47 PM
Mark 42
Electrical Systems/Wiring
01-11-2005 01:53 PM
Quick Reply: how to remove front headlight assembly?
