EEC - IV Can i take one off a 92 and put it on a 95 both F250 with 460 engines
I beleive that the EEC - IV PCM is bad in my 95 F250 with a 460 engine. I have a 92 F250 also with a 460 engine as a parts truck. Can i switch from one truck to the other? Both have the EEC - IV computer. My 95 truck will not start. I have Spark (new plugs, wires and distributer cap), and proper fuel pressure (new fuel filter). Several of the sensors do not have proper voltage going to them from the PCM which is why i think i may have a bad PCM. Any advice would be helpfull. Thanks
Gotta give a few ideas quickly..
Be sure that both trucks have the same transmissions...PCM for a AOD won't work for a E4OD trans...Same if one's Standard and the other is auto.
If your voltage for the BAD PCM is not within spec, PULL the PCM. If you have time, take the PCM aprt. Look at the Capacitors. More than likely if a CAP is leaking, crusty, or blown up, that's your voltage problem.
The 92 is for a push start Ignition system and the 95 is for a CCD Ignition system.
They require different wiring under the hood and different ICM.
Do you have the calibration number off the door if it is a E250 or E350.
If it is a class "A" what are the three letters at the bottom left on the vacuum diagram sticker on the valve cover on the drivers side.
and on an Automatic equipped truck Not being a Smart Axx I'm curious lol
In the case that the SPOUT signal line opens from the PCM, the ICM will use the PIP signal to fire the coil. This results in a fixed spark angle and fixed dwell.
Push-Start system:
CCD system:
f18cowboy
26
04-15-2023 04:40 PM
