4.9L fuel pump wiring
92 4.9L
--fuel pump went dead. I banged on the pump and wiggled the wire harness for a minute and it started up and ran long enough for me to drive it home.
Died again at the store.
I ran a test on the wires...got two out of the five to read hot. Very weird readings though...the red wire hit something like 166.4...didn't even make sense (volt meter set on fused 12v)
Second hot wire ran somewhere around 4.7.
I picked up a new fuel pump but now im starting to wonder if it's actually just my wiring that's going bad.
Next step i suppose is to run a 20a fused wire from the battery to the fuel pump and see if it runs. I rotated the three relays in the power box also to see if i had a weak relay...didn't help.
The truck has had throttle response and acceleration problems...running lean...basically starving for fuel and i have suspected the pump for at least a month....DOES ANYONE have some input--bad pump???
Well, i cannot find the wiring diagram and specs for voltage, etc for the 5 wires going to the pump...any help?? Much thanks
Ray Mathews
06-03-2021 06:40 AM
subjlog
06-14-2017 08:36 AM
Sara LeeAnn Charles
04-07-2017 07:55 AM
jozepy24
51
04-14-2011 03:24 PM
